Soil - Bearing Strength
Allowable bearing strength of soil:
SoilBearing Load
(kPa)
Clay, soft 100
Sand, dry fine 200
Sand with clay, dry fine 300
Sand, coarse 300
Clay, dry hard 350
Gravel 400
Rock 1000 - 4000
  • 1 kPa = 1 kNm2 = 103 N/m2
Always check local building codes.
Statics
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Trench Excavation
Estimate trench excavation - online calculator.
