Bases - pH Values
pH is a measure of the hydrogen ion (H+) activity in a solution and, therefore, its acidity or alkalinity.
Values for some common bases:
Base | Normality | pH |
Ammonia | N | 11.5 |
Ammonia | 0.1 N | 11.1 |
Ammonia | 0.01 N | 10.6 |
Barbital sodium | 0.1N | 9.4 |
Borax | 0.01 N | 9.2 |
Calcium carbonate | saturated | 9.4 |
Calcium hydroxide | saturated | 12.4 |
Ferrous hydroxide | saturated | 9.5 |
Magnesia | saturated | 10.5 |
Lime | saturated | 12.4 |
Potassium acetate | 0.1N | 9.7 |
Potassium bicarbonate | 0.1N | 8.2 |
Potassium carbonate | 0.1N | 11.5 |
Potassium cyanide | 0.1 N | 11.0 |
Potassium hydroxide | N | 14.0 |
Potassium hydroxide | 0.1 N | 13.0 |
Potassium hydroxide | 0.01 N | 12.0 |
Sodium acetate | 0.1N | 8.9 |
Sodium benzoate | 0.1N | 8.0 |
Sodium bicarbonate (baking soda) |
0.1 N | 8.4 |
Sodium carbonate (washing soda) |
0.1 N | 11.6 |
Sodium hydroxide (caustic soda) |
N | 14.0 |
Sodium hydroxide | 0.1 N | 13.0 |
Sodium hydroxide | 0.01 N | 12.0 |
Sodium metasilicate | 0.1 N | 12.6 |
Sodium sesquicarbonate | 0.1 N | 10.1 |
Trisodium phosphate | 0.1 N | 12.0 |
• Environment
Acid and Base pH Indicators
pH range vs. color change for acid and base indicators - together with pKa and structures of the indicators.
Acids - pH Values
pH values of acids like sulfuric, acetic and more..
Amines, Diamines and Cyclic Organic Nitrogen Compounds - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of the conjugated acid of amines, diamines and cyclic organic nitrogen compounds, shown together with the molecular structure of the acids.
Aqueous Salt Solutions - Acid and Base Properties
Salts contains ions that may affect the pH in aqueous solutions in both acidic and basic directions.
Buffer Solutions
Definitions, explanations and examples of how to make buffer solutions.
Food and Foodstuff - pH Values
pH in common food products - like apples, butter, wines and more.
Inorganic Acids and Bases - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
pH - Basic (alkaline) vs. Acidic
Introduction to pH - the acidic and basic (alkaline) definition.
Phenols, Alcohols and Carboxylic Acids - pKa Values
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
Potassium - Thermophysical Properties vs. Temperature
Thermophysical properties of potassium.
Strong and Weak Acids and Bases
The most common strong acids and bases, and some examples of weak acids and bases, together with definition of strong and weak acids and bases.
