Cation has no effect on pH
pH range vs. color change for acid and base indicators - together with pKa and structures of the indicators.
pH values of acids like sulfuric, acetic and more..
Values for the negative logarithm of the acid dissociation constant, pKa, of the conjugated acid of amines, diamines and cyclic organic nitrogen compounds, shown together with the molecular structure of the acids.
pH values for bases like sodium hydroxide, ammonia and more.
Definitions, explanations and examples of how to make buffer solutions.
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
The most common strong acids and bases, and some examples of weak acids and bases, together with definition of strong and weak acids and bases.
