Maximum capacities of condensate lines in kW steam consumption
Recommended capacities (lb/hour) in gravity condensate return lines
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Flash steam produced by hot water and condensate
An introduction to the basic design of steam heating systems
The danger of impeller cavitations increases with water temperature
Comparing flow coefficient Cv with flow factor Kv
A table for estimating capacity of condensate piping lines
Calculate fluid flow and pipe velocity
Pipes expands when heated and contracts when cooled. The expansion of the pipes can be expressed with the expansion formula
Steam pipes and pressure drop diagrams - imperial and metric units
A steam table with sensible, latent and total heat, and specific volume at different gauge pressures and temperatures
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
A table for sizing condensate return lines in steam distribution systems
Steam is a compressible gas where the mass flow capacity of the pipe lines depends on the steam pressure. This table, where pressure is in bar, velocity in m/s and capacity in kg/h, is suitable for sizing steam pipes
Steam is a compressible gas where the capacity of the pipe line depends on the size of the pipes and the steam pressure. This table can be used for fast sizing of steam pipes dimensions
Flow rate (lb/h) and pressure drop per 100 feet of pipes sizing 3/4" to 12"
Calculating the amount of steam in non-flow batch and continuous flow heating processes
Calculate pressure drop in steam distribution pipe lines
Pipe sizing steam systems - major and minor loss in steam distribution systems
Selection of steam traps and safety factors
Steel pipes - thermal expansion and expansion loop capacities
Calculate the stress in in a steam boiler shell from pressure
Thermal heating and cooling expansion of pipes in cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum
When a steam pipes is heated from surrounding temperature to operation temperature - it expands
A steam pipe heated from surrounding temperature to operation temperature expands
9 11 11
