Steam Heating Systems - Classifications
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Steam is commonly used to distribute heat from a boiler to consumers like heat exchangers, process equipment etc. Steam is also used for heating buildings.
Steam systems can be classified by pressure, method for returning condensate and/or pipe lay out.
Classification of Steam Systems by Pressure
Its common to classify steam systems as
  • High pressure above 20 kN/m2 (3 lb/in2)
  • Low pressure up to 20 kN/m2 (3 lb/in2)
  • Vacuum
Classification of Steam Systems by Method of Condensate Return
Steam systems can be classified as
  • Gravity
  • Mechanical
Classification of Steam Systems by Pipe Lay Out
Steam systems can be classified by pipe scheme:
  • One pipe or two pipe
  • Up-feed or down-feed
