Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
The steam velocities or speeds below are commonly recommended as acceptable for steam distribution systems:
Steam SystemVelocity
(m/s)(ft/s)
Saturated Steam - high pressure 25 - 40 82 - 131
Saturated Steam - medium and low pressure 30-40 99 - 131
Saturated Steam at peak load < 50 < 164
Steam and Water mix < 25 < 82
Superheated Steam 35 - 100 100 - 300
  • Saturated steam - low pressure - is common for heating services and secondary process pipes.
  • Saturated steam - high pressure - is common in powerhouse, boiler and main process lines.
  • Superheated steam is common in power generation and turbine plants.
  • The Engineering ToolBox (2003). Recommended Velocities in Steam Systems. [online] Available at: https://www.engineeringtoolbox.com/flow-velocity-steam-pipes-d_386.html [Accessed Day Month Year].
