Wire Size Guide: Square mm to Diameter Conversion Chart
Use the table below to convert between wire square mm and diameter mm.
Note that for the real outside diameter of a given cable - the insulation thickness must be added.
Wire Size - Area to Diameter Converter
mm2mm
0.75 1.0
1 1.1
1.5 1.4
2 1.5
2.5 1.8
4 2.3
6 2.8
10 3.6
16 4.5
25 5.6
35 6.7
50 8.0
70 9.5
95 11.0
120 12.4
150 13.8
185 15.4
240 17.5
300 19.5
400 22.6
500 25.2
630 28.3
800 31.9
1000 35.7
1200 39.1
2000 50.5
Download an print mm to mm2 diagram
Electrical
12 Volt - Amps Amps vs. Wire Gauge: Choosing the Right Wire Size
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
AWG - Wire Gauge Sizes: Current Ratings, Charts, Measurements, and Conversion Guide
Amp ratings vs. US AWG wire gauge.
