Gallons vs. Pounds of Water Converter
Convert Gallons of Water to Pounds
w = 8.33 q (1)
w = weight of water (lb)
q = volume of water (US gallons)
The equation is based on water with temperature 68oF (20oC) and specific weight 8.33 lb/US gal.
Example - Converting Gallons of Water to Pounds
50 gallons of water can be converted to pounds as
w = 8.33 (50 gallons)
= 416.5 lb
Convert Pounds of Water into Gallons
q = w / 8.33 (1b)
• Basics
The SI-system, unit converters, physical constants, drawing scales and more.
Mass vs. Weight
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
