Walls - No. of Studs
Quantity of studs in a wall can be calculated as
n = L / l + 1                                (1)
n = number of studs
L = length of wall (ft, m)
l = center distance between the studs (ft, m)
Additional studs are required in corners and around doors and windows.
Miscellaneous
Building Tolerances
Typical tolerances for floors, walls, columns and more.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Walls - Volume
Estimate concrete wall volume.
Heat Transmission Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
Low-Frequency Vibrations Effects on Building Constructions
Effects of low-frequency vibrations on building constructions.
Moisture Transport through Walls and Roofs
Moisture will flow through a building wall or roof if the vapor partial pressure is higher on one of the sides.
Roof Framing
Run, roof slope, gable height and gable area.
Sound Transmission through Massive Walls or Floors
Sound transmission and attenuation in building elements like massive concrete walls or floors.
