Nominal Size (in) | Allowable Pressure (psi) | ||
Temperature (oF) | |||
100 | 200 | 300 | |
1/8 | 1960 | 1960 | 1710 |
1/4 | 2210 | 2210 | 1930 |
3/8 | 1840 | 1840 | 1610 |
1/2 | 1760 | 1760 | 1540 |
3/4 | 1510 | 1510 | 1320 |
1 | 1340 | 1340 | 1180 |
1 1/4 | 1160 | 1160 | 1020 |
1 1/2 | 1090 | 1090 | 960 |
2 | 1000 | 1000 | 870 |
2 1/2 | 970 | 970 | 850 |
3 | 910 | 910 | 790 |
Standard sizes specification for seamless red brass pipes.
