Piping - Codes & Standards
The integrity of a piping system depends on the considerations and principles used in design, construction and maintenance of the system. Piping systems are made of components as pipes, flanges, supports, gaskets, bolts, valves, strainers, flexible and expansion joints. The components can be made in a variety of materials, in different types and sizes and may be manufactured to common national standards or according a manufacturers proprietary item. Some companies even publish their own internal piping standards based upon national and industry sector standards.
Piping codes and standards from standardization organizations as
and others, are the most common used.
The difference between piping codes and piping standards can be summarized:
Piping Codes
Piping codes defines the requirements of design, fabrication, use of materials, tests and inspection of pipes and piping systems - what you need to do.
A code has a limited jurisdiction defined by the code. A code is not law, but can be adopted into law.
Example:
"ASME B31.1 (2007), Code for Pressure Piping, Section on Power Piping, as required by the laws of the States of Arizona, Alaska, Colorado, Illinois, Iowa, Kansas, Michigan, Missouri, Minnesota, Nebraska, Nevada, North Dakota, Ohio, Oregon, Wisconsin, et. alia."
Piping Standards
Piping standards define application design and construction rules and requirements for piping components as flanges, elbows, tees, valves etc. - how to do it.
A standard has a limited scope defined by the standard.
• Codes and Standards
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASME - Performance Test Codes
The ASME Performance Test Codes provide standard directions and rules for conducting and reporting tests.
CSI MasterFormat Specifications
Construction Specifications Institute's 2004 Master-Format Edition.
DIN - Deutsches Institut für Normung
DIN - the German Institute for Standardization.
ISO - International Organization for Standardization
ISO - the International Organization for Standardization.
ISO - Pipe, Tube and Fittings Standards and Specifications
International Organization for Standardization - ISO - pipe, tube and fittings standards and specifications.
