Internal Rate of Return - IRR
A primary measure of an investments worth (or value) is based on yield and known as the internal rate of return - IRR .
The internal rate of return can be defined as the break-even interest rate which equals the Net Present Worth - NPW - (Net Present Value) of a project in and out cash flows.
P(i rr ) = F cash_in - F cash_out
= 0                    (1)
P = Present Worth (Value)
i rr = internal rate of return
F cash_in = future cash flow in ( discounted )
F cash_out = future cash flow out ( discounted)
(1) can be expressed as
P(i rr ) = F 0 / (1 + i rr ) 0 + F 1 / (1 + i rr ) 1 + F2/(1 + i rr )2+ .... + F n /(1 + i rr ) n
= 0                    (2)
F 0..n = cash flow in period 0 to n (positive value for cash flow in - negative value for cash flow out)
For a given cash flow equation (2) can be solved by iteration.
Cash Flow Internal Rate of Return Calculator
  • money out - negative values
  • money in - positive values
Cash Flows - Period
Download and print Present Value of Future Payment chart
Minimum Attractive Rate of Return - MARR
Minimum Attractive Rate of Return - MARR - represents the required or minimum acceptable Internal Rate of Return for a project investment.
Economics
Engineering economics - cash flow diagrams, present value, discount rates, internal rates of return - IRR, income taxes, inflation.
Accounting Rate of Return
Net income vs net investment.
Cash Flow Diagrams
The future value of money.
Contract Types
Commonly used engineering and construction contracts.
Discrete Compounding Cash Flow Formulas
Discrete payments compounding equations and online calculators .
Interest Formulas
Future value of single cash flow.
Interest Rate
Interest rate is the cost of money.
Net Present Worth (NPW) of a Cash Stream
The value of a stream of payments is called the Net Present Worth (NPW).
Present Value
The value of money in the future is the Present Value.
Uniformat
The ASTM E1557 UNIFORMAT II Standard.
Value Engineering
Improved value by enhanced function.
