Industrial Environments - Selecting Ventilation System
A quick selection guide to ventilation system principles in industrial environments:
Industrial Environments - Alternative Ventilation System
VentilationHeatingCoolingMixedDisplacement
CAVVAVCAVVAV
1 1 1 x
1 5 1 x
1 5 5 x (x)
1 1 5 x (x)
5 1 1 x
5 5 1 x
5 5 5 x x
5 1 5 x
1 = not or little suitable, 5 = suitable
  • VAV - Variable Air Volume - the temperature of the supply air remains constant, but the air volume varies
  • CAV - Constant Air Volume - the volume of air supply remains constant, but the temperature varies
Constant Air Volume - CAV - systems are becoming less common in new buildings since VAV systems provides closer control of air temperature and requires lower fan speeds, resulting in less energy consumption and less noise.
Ventilation
