HVAC Dampers - Pressure Loss
Typical pressure - or head - loss in a HVAC damper:
Ventilation
The equal friction method for sizing air ducts is easy and straightforward to use.
Fans - Capacity Control
How to modulate fans and their capacities.
Noise generated in Blade Dampers
Sound power noise generated by blade dampers in ventilation systems.
Ventilation Dampers - Classification
Dampers in ventilation systems may be classified through function, construction or leakage class.
