Forces acting on Body Moving on a Horizontal Plane
The force pushing - or pulling - a body along a horizontal surface can be expressed as
Q = F cos(α) (1)
Q = force moving the body in horizontal direction (N, lb)
α = angle between force F and horizontal plane
The force acting in vertical direction can be calculated as:
P = (F2 - Q2)1/2 (2)
P = force acting in vertical direction (N, lb)
Example - Strong Man Pulling a Truck
A "strong man" is pulling a truck by exerting a force of 1000 N. The force is acting 30o to the horizontal plane.
The horizontal force on the truck can be calculated as
Q = (1000 N) cos(30o)
= 866 N
= 0.87 kN
The vertical force "lifting" truck can be calculated as
P = ((1000 N)2 - (866 N)2)1/2
= 500 N
= 0.5 kN
Horizontal and Vertical Force Calculator
The calculator below can used to calculate the horizontal and vertical forces:
• Mechanics
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Bodies Moving on Inclined Planes - Acting Forces
Required forces to move bodies up inclined planes.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Mass vs. Weight
