District Heating - Heat Capacity vs. Temperature
An increase in the hot water supply temperature will reduce the volume flow in a district heating system where the required heat is constant.
Supply Temperature (oC) | Required Water Flow (liters/kW) |
90 | 28.7 |
100 | 21.5 |
112 | 16.4 |
120 | 14.3 |
133 | 11.8 |
150 | 9.6 |
180 | 7.2 |
- based on 60 oC return temperature
• Heating Systems
Design of Hot Water Heating Systems
Calculate gravity and forced circulating hot water heating systems.
Heating System Flow Rates
Calculate flow rates in heating systems.
Hot Water Heating System - Design Procedure
Hot water heating system design procedure with heat loss, boiler rating, heater units and more.
Hot Water Heating System Online Design Application
Hot-Water Heating Systems - Classification
Hot-water heating systems can be classified by temperature and pressure.
