Weirs Flow Meters - Standards
Methods for flow measurement are described in detail in international standards, national standards, association standards and numerous hydraulic textbooks and handbooks. Some of the most used standardization organizations are:
  • the International Organization for Standardization (ISO)
  • the American Society for Testing and Materials (ASTM)
  • the American Society of Mechanical Engineers (ASME)
  • the British Standards Institute (BSI)
  • the National Institute for Science and Technology (NIST)
ASTM Flow Standards - the American Society of Mechanical Engineers
  • ASTM D 5242 - STANDARD TEST METHOD FOR OPEN-CHANNEL FLOW MEASUREMENT OF WATER WITH THIN-PLATE WEIRS
  • ASTM D 5614 - STANDARD TEST METHOD FOR OPEN CHANNEL FLOW MEASUREMENT OF WATER WITH BROAD-CRESTED WEIRS
  • ASTM D 5640 - STANDARD GUIDE FOR SELECTION OF WEIRS AND FLUMES FOR OPEN-CHANNEL FLOW MEASUREMENT OF WATER
  • ASTM D 5716 - STANDARD TEST METHOD FOR MEASURING THE RATE OF WELL DISCHARGE BY CIRCULAR ORIFICE WEIR
AWWA Flow Standards - the American Water Works Association
  • AWWA C909 - MATCHED-DIE-MOLDED, FIBERGLASS-REINFORCED PLASTIC WEIR PLATES, SCUM BAFFLES, AND MOUNTING BRACKETS
  • AWWA F102 - MATCHED-DIE-MOLDED, FIBERGLASS-REINFORCED PLASTIC WEIR PLATES, SCUM BAFFLES, AND MOUNTING BRACKETS
BS Flow Standards - the British Standards Institute
  • BS 3680 P4A - METHOD USING THIN-PLATE WEIRS
  • BS 3680 P4B - TRIANGULAR PROFILE WEIRS
  • BS 3680 P4E - RECTANGULAR BROAD-CRESTED WEIRS
  • BS 3680 P4I - V-SHAPED BROAD CRESTED WEIRS
  • BS 3680-4F - ROUND NOSE HORIZONTAL BROAD-CRESTED WEIRS
  • BS ISO 4377 - HYDROMETRIC DETERMINATIONS - FLOW MEASUREMENT IN OPEN CHANNELS USING STRUCTURES - FLAT-V WEIRS
DIN Flow Standards - Deutsches Institut für Normung eV
  • DIN 19558 - SEWAGE TREATMENT PLANTS; WEIR AND SCUM BAFFLE; ARRANGEMENT, MAIN DIMENSIONS AND OVERFLOW RATE
GOST Flow Standards - Russian Federation
  • GOST R 51657.4 - WATER FLOW MEASUREMENT IN HYDROMELIORATION AND WATER SUPPLY SYSTEMS. WATER DISCHARGE MEASUREMENT IN OPEN CHANNELS BY TRIANGULAR PROFILE WEIRS. GENERAL TECHNICAL REQUIREMENTS
ISO Flow Standards - International Organization for Standardization
  • ISO 1438/1 - WATER FLOW MEASUREMENT IN OPEN CHANNELS USING WEIRS AND VENTURI FLUMES - PART 1: THIN-PLATE WEIRS
  • ISO 3846 - LIQUID FLOW MEASUREMENT IN OPEN CHANNELS BY WEIRS AND FLUMES - RECTANGULAR BROAD - CRESTED WEIRS
  • ISO 3847 - LIQUID FLOW MEASUREMENT IN OPEN CHANNELS BY WEIR
  • ISO 4360 - LIQUID FLOW MEASUREMENT IN OPEN CHANNELS BY WEIRS
  • ISO 4362 - MEASUREMENT OF LIQUID FLOW IN OPEN CHANNELS TRAPEZOIDAL PROFILE WEIRS
  • ISO 4374 - LIQUID FLOW MEASUREMENT IN OPEN CHANNELS - ROUND-NOSE HORIZONTAL BROAD-CRESTED WEIRS
  • ISO 4377 - HYDROMETRIC DETERMINATIONS - FLOW MEASUREMENT IN OPEN CHANNELS USING STRUCTURES - FAT-V WEIRS
  • ISO 8333 - LIQUID FLOW MEASUREMENT IN OPEN CHANNELS BY WEIRS
  • ISO 9827 - MEASUREMENT OF LIQUID FLOW IN OPEN CHANNELS BY WEIRS AND FLUMES - STREAMLINED TRIANGULAR PROFILE WEIRS
SAA Flow Standards - Standards Australia
  • SAA AS 3778.4.1 - MEASUREMENT USING FLOW GAUGING STRUCTURES - THIN-PLATE WEIRS
  • SAA AS 3778.4.2 - MEASUREMENT USING FLOW GAUGING STRUCTURES - RECTANGULAR BROAD- CRESTED WEIRS
  • SAA AS 3778.4.3 - MEASUREMENT USING FLOW GAUGING STRUCTURE - ROUND-NOSE HORIZONTAL BROAD-CRESTED WEIRS
  • SAA AS 3778.4.4 - MEASUREMENT USING FLOW GAUGING STRUCTURES - V-SHAPED BROAD-CRESTED WEIRS
  • SAA AS 3778.4.5 - MEASUREMENT USING FLOW GAUGING STRUCTURES - TRIANGULAR PROFILE WEIRS
  • SAA AS 3778.4.6 - MEASUREMENT USING FLOW GAUGING STRUCTURE - FLAT-V WEIRS
TAPPI Flow Standards
  • TAPPI TIP 0410-10 - WEIRS AND FLUMES
Flow Measurement
Open Channel Weirs - Volume Flow Measurements
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
