- produced in synthetic fibers
- efficient for particles
> 4-5 mm
- air speed < 2.5 m/s
- start pressure drop approximately 50 Pa
- final pressure drop approximately 150 Pa
Air filters efficiency and arrestance.
Pressure loss in ventilation system components like dampers, filters, heaters, coolers and more.
