The weight of roofing constructions above the truss/rafter may be estimated with the calculator below.
Roofing Materials
None Asphalt roll roofing (1.1 lbm /ft2 , 5.4 kg/m2 ) Asphalt shingle or asphalt-fiberglass composite shingle (2.7 lbm /ft2 , 13.2 kg/m2 ) Metal roofing - aluminum or steel - panel, sheet or shingle (1.2 lbm /ft2 , 5.9 kg/m2 ) Terne plate - copper bearing steel sheet (0.7 lbm /ft2 , 3.4 kg/m2 ) Wood shingle or shake (2.4 lbm /ft2 , 11.7 kg/m2 ) Zinc roofing (1.6 lbm /ft2 , 7.8 kg/m2 ) Copper-asphalt composite shingle (4.2 lbm /ft2 , 20.5 kg/m2 ) Asphalt roll roofing (1.1 lbm /ft2 , 5.4 kg/m2 ) Felt, tar and gravel roofing - 3 ply (4.8 lbm /ft2 , 23.4 kg/m2 ) Felt, tar and gravel roofing - 4 ply (5.3 lbm /ft2 , 25.9 kg/m2 ) Felt, tar and gravel roofing - 5 ply (6.1 lbm /ft2 , 29.8 kg/m2 ) Felt, tar and slag roofing - 3 ply (4.5 lbm /ft2 , 22 kg/m2 ) Felt, tar and slag roofing - 4 ply (4.8 lbm /ft2 , 23.4 kg/m2 ) Felt, tar and slag roofing - 5 ply (5.3 lbm /ft2 , 25.9 kg/m2 ) Ceramic slate (5.8 lbm /ft2 , 28.3 kg/m2 ) Reconstituted slate (4.4 lbm /ft2 , 21.5 kg/m2 ) Clay tile (10.8 lbm /ft2 , 52.7 kg/m2 ) Asphalt roll roofing (1.1 lbm /ft2 , 5.4 kg/m2 ) Concrete tile (9.3 lbm /ft2 , 45.4 kg/m2 ) Slate - 1/4" to 3/16 thick (9.1 lbm /ft2 , 44.4 kg/m2 ) Slate - 3/8" thick (12.8 lbm /ft2 , 62.5 kg/m2 ) Slate - 1/2" thick (18.8 lbm /ft2 , 91.8 kg/m2 ) Slate - 3/4" thick (26.0 lbm /ft2 , 127 kg/m2 )
Sheating Materials
Plywood
None 5/16" thick (1.0 lbm /ft2 , 4.9 kg/m2 ) 3/8" thick (1.1 lbm /ft2 , 5.4 kg/m2 ) 7/16" thick (1.3 lbm /ft2 , 6.3 kg/m2 ) 15/32" thick (1.4 lbm /ft2 , 6.8 kg/m2 ) 1/2" thick (1.5 lbm /ft2 , 7.3 kg/m2 ) 19/32" thick (1.8 lbm /ft2 , 8.8 kg/m2 ) 5/8" thick (1.9 lbm /ft2 , 9.3 kg/m2 ) 23/32" thick (2.2 lbm /ft2 , 10.7 kg/m2 ) 3/4" thick (2.3 lbm /ft2 , 11.2 kg/m2 ) 7/8" thick (2.3 lbm /ft2 , 11.2 kg/m2 ) 1" thick (3.0 lbm /ft2 , 14.6 kg/m2 ) 1 1/8" thick (3.3 lbm /ft2 , 16.1 kg/m2 )
Oriented Strand Board (OSB), Com-Ply
5/16" thick (1.1 lbm /ft2 , 5.4 kg/m2 ) 3/8" thick (1.2 lbm /ft2 , 5.9 kg/m2 ) 7/16" thick (1.4 lbm /ft2 , 6.8 kg/m2 ) 15/32" thick (1.5 lbm /ft2 , 7.3 kg/m2 ) 1/2" thick (1.7 lbm /ft2 , 8.3 kg/m2 ) 19/32" thick (2.0 lbm /ft2 , 9.8 kg/m2 ) 5/8" thick (2.1 lbm /ft2 , 10.3 kg/m2 ) 23/32" thick (2.4 lbm /ft2 , 11.7 kg/m2 ) 3/4" thick (2.5 lbm /ft2 , 12.2 kg/m2 ) 7/8" thick (2.9 lbm /ft2 , 14.2 kg/m2 ) 1" thick (3.3 lbm /ft2 , 16.1 kg/m2 ) 1 1/8" thick (3.6 lbm /ft2 , 17.6 kg/m2 )
Underlayment Materials
Asphalt impregnated felt paper
None 15 pound paper (0.2 lbm /ft2 , 1 kg/m2 ) 30 pound paper (0.3 lbm /ft2 , 1.5 kg/m2 ) 45 pound paper (0.5 lbm /ft2 , 2.4 kg/m2 )
Note! - the weight of truss/rafter must be added to calculate the dead load of the roof.
Chimneys and single wall vents roof termination.
Douglas Fir in horizontal roof rafters and maximum spans.
Moisture will flow through a building wall or roof if the vapor partial pressure is higher on one of the sides.
Capacities of vertical downspouts when draining roof areas in rainfall.
Run, roof slope, gable height and gable area.
