Riser Diagrams
Vertically supply lines are known as risers.
• Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Contact - Citation - Copyrights - Advertising - Warranty and Liability
