Amount of Rain (in) | Weight of Water (lb/ft2) |
6 | 31.2 |
5 | 26.0 |
4 | 20.8 |
3 | 15.6 |
2 | 10.4 |
1 | 5.2 |
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Capacities of horizontal storm drain piping systems.
Capacities of vertical downspouts when draining roof areas in rainfall.
Draining of roof areas and recommended gutter slopes
Roof drain capacities.
Storm-water runoff coefficients for various surfaces
