Periodic Table of Elements
For full table with all elements - rotate the screen!
Group | |||||||||||||||||||||||||||||||
1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | ||||||||||||||
1 H |
2 He |
3 Li |
4 Be |
5 B |
6 C |
7 N |
8 O |
9 F |
10 Ne |
11 Na |
12 Mg |
13 Al |
14 Si |
15 P |
16 S |
17 Cl |
18 Ar |
19 K |
20 Ca |
21 Sc |
22 Ti |
23 V |
24 Cr |
25 Mn |
26 Fe |
27 Co |
28 Ni |
29 Cu |
30 Zn |
31 Ga |
32 Ge |
33 As |
34 Se |
35 Br |
36 Kr |
37 Rb |
38 Sr |
39 Y |
40 Zr |
41 Nb |
42 Mo |
43 Tc |
44 Ru |
45 Rh |
46 Pd |
47 Ag |
48 Cd |
49 In |
50 Sn |
51 Sb |
52 Te |
53 I |
54 Xe |
55 Cs |
56 Ba |
57 La |
58 Ce |
59 Pr |
60 Nd |
61 Pm |
62 Sm |
63 Eu |
64 Gd |
65 Tb |
66 Dy |
67 Ho |
68 Er |
69 Tm |
70 Yb |
71 Lu |
72 Hf |
73 Ta |
74 W |
75 Re |
76 Os |
77 Ir |
78 Pt |
79 Au |
80 Hg |
81 Tl |
82 Pb |
83 Bi |
84 Po |
85 At |
86 Rn |
87 Fr |
88 Ra |
89 Ac |
90 Th |
91 Pa |
92 U |
93 Np |
94 Pu |
95 Am |
96 Cm |
97 Bk |
98 Cf |
99 Es |
100 Fm |
101 Md |
102 No |
103 Lr |
104 Rf |
105 Db |
106 Sg |
107 Bh |
108 Hs |
109 Mt |
110 Ds |
111 Rg |
112 Cn |
Atomic Number | Chemical Element Name | Symbol |
1 | Hydrogen | H |
2 | Helium | He |
3 | Lithium | Li |
4 | Beryllium | Be |
5 | Boron | B |
6 | Carbon | C |
7 | Nitrogen | N |
8 | Oxygen | O |
9 | Fluorine | F |
10 | Neon | Ne |
11 | Sodium | Na |
12 | Magnesium | Mg |
13 | Aluminum | Al |
14 | Silicon | Si |
15 | Phosphorus | P |
16 | Sulfur | S |
17 | Chlorine | Cl |
18 | Argon | Ar |
19 | Potassium | K |
20 | Calcium | Ca |
21 | Scandium | Sc |
22 | Titanium | Ti |
23 | Vanadium | V |
24 | Chromium | Cr |
25 | Manganese | Mn |
26 | Iron | Fe |
27 | Cobalt | Co |
28 | Nickel | Ni |
29 | Copper | Cu |
30 | Zinc | Zn |
31 | Gallium | Ga |
32 | Germanium | Ge |
33 | Arsenic | As |
34 | Selenium | Se |
35 | Bromine | Br |
36 | Krypton | Kr |
37 | Rubidium | Rb |
38 | Strontium | Sr |
39 | Yttrium | Y |
40 | Zirconium | Zr |
41 | Niobium | Nb |
42 | Molybdenum | Mo |
43 | Technetium | Tc |
44 | Ruthenium | Ru |
45 | Rhodium | Rh |
46 | Palladium | Pd |
47 | Silver | Ag |
48 | Cadmium | Cd |
49 | Indium | In |
50 | Tin | Sn |
51 | Antimony | Sb |
52 | Tellurium | Te |
53 | Iodine | I |
54 | Xenon | Xe |
55 | Cesium | Cs |
56 | Barium | Ba |
57 | Lanthanum | La |
58 | Cerium | Ce |
59 | Praseodymium | Pr |
60 | Neodymium | Nd |
61 | Promethium | Pm |
62 | Samarium | Sm |
63 | Europium | Eu |
64 | Gadolinium | Gd |
65 | Terbium | Tb |
66 | Dysprosium | Dy |
67 | Holmium | Ho |
68 | Erbium | Er |
69 | Thulium | Tm |
70 | Ytterbium | Yb |
71 | Lutetium | Lu |
72 | Hafnium | Hf |
73 | Tantalum | Ta |
74 | Tungsten | W |
75 | Rhenium | Re |
76 | Osmium | Os |
77 | Iridium | Ir |
78 | Platinum | Pt |
79 | Gold | Au |
80 | Mercury | Hg |
81 | Thallium | Tl |
82 | Lead | Pb |
83 | Bismuth | Bi |
84 | Polonium | Po |
85 | Astatine | At |
86 | Radon | Rn |
87 | Francium | Fr |
88 | Radium | Ra |
89 | Actinium | Ac |
90 | Thorium | Th |
91 | Protactinium | Pa |
92 | Uranium | U |
93 | Neptunium | Np |
94 | Plutonium | Pu |
95 | Americium | Am |
96 | Curium | Cm |
97 | Berkelium | Bk |
98 | Californium | Cf |
99 | Einsteinium | Es |
100 | Fermium | Fm |
101 | Mendelevium | Md |
102 | Nobelium | No |
103 | Lawrencium | Lr |
104 | Rutherfordium | Rf |
105 | Dubnium | Db |
106 | Seaborgium | Sg |
107 | Bohrium | Bh |
108 | Hassium | Hs |
109 | Meitnerium | Mt |
110 | Darmstadtium | Ds |
111 | Roentgenium | Rg |
112 | Ununbium | Uub |
113 | Ununtrium | Uut |
114 | Ununquadium | Uuq |
115 | Ununpentium | Uup |
116 | Ununhexium | Uuh |
117 | Ununseptium | Uus |
118 | Ununoctium | Uuo |
• Basics
Elements - Boiling Points
Elements and their boiling points.
Radioisotopes - Half Lives
Time for isotop radiation to be reduced with 50%.
