Measurements - Absolute vs. Relative Frequencies
Measurements are important in all production processes to achieve required quality.
A measurement data set can be like the weight samples of a product:
Sample
no.
Sample Value
- x -
1 1.0
2 1.1
3 0.9
4 1.0
5 1.0
6 0.9
7 1.1
8 1.0
9 1.1
The absolute frequencies for the each measured value:
Sample Value
- x -
Absolute Frequency
- h -
0.9 2
1.0 4
1.1 3
The data set size corresponds to the number of samples and the total of the absolute frequencies:
n = h1 + h2 + .. + hk
   = Σ hi  (1 < i < k)                                              (1)
n = no. samples
h = absolute frequency of sample measurement
The relative frequency can be expressed as
fi = hi / n                                      (2)
fi = relative frequency of sample
Adding all relative frequencies produces value 1.
Σ fi = 1  (1 < i < k)                             (3)
The arithmetic mean (average value) can be calculated as
Mathematics
Length Units Converter
Convert between units like metre, feet, inches, yards, kilometers and miles.
Measurements
Measurements are required to monitor, analyze and control processes.
Open Channel Weirs - Volume Flow Measurements
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
ISA process instrumentation codes - and combinations.
Some Measuring Units
Commonly used measuring units - like gross, dozen, quire, sheets and more.
