Noise from Machines - Enclosures and Sound Pressure Level Reductions
The noise levels from machines can be reduced with barriers or enclosures as indicated below:
Type of EnclosureSound Pressure Level Reduction
(dBA)
1 No enclosure or barrier, machine alone 0
2 Machine on vibration isolators ≈ 2
3 Machine with barrier ≈ 5
4 Machine in a rigid and sealed enclosure ≈ 20 - 25
5 Machine in a rigid and sealed enclosure with sound absorption lining on inside walls - machine on vibration mounts ≈ 40 - 45
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Fans - Noise Power Generation
Propagation of Outdoor Sound - Partial Barriers
The transmission of outdoor sound through and around barriers - the Fresnel Number.
Propagation of Sound Indoors - the Room Constant
In a room the sound or noise will reach the receiver as direct and reverberant sound.
Sound Propagation - the Inverse Square Law
Doubling of the distance from a noise source reduces the sound pressure level with 6 decibel.
Sound Transmission through Massive Walls or Floors
Sound transmission and attenuation in building elements like massive concrete walls or floors.
