Greenhouses - Heat Required to Maintaining Temperature
A greenhouse heat loss due to
- transmission through glass
- allowance for infiltration
at outside temperatures ranging -10 to 20 degrees Fahrenheit (-23 to -7 degrees C):
Example - Heat Loss from a Greenhouse
With an inside temperature 15 oC and an outside temperature -10 oC the heat loss from a greenhouse is aprox. 18 kW per 100 m2 floor area.
• Heating Systems
Greenhouse Pipes - Heat Emission
Heat emission from steam and hot water pipes typical used in greenhouse installations.
Greenhouses - Typical Temperatures
Typical greenhouse temperatures.
