Charles' Law
Charles' law states that in a perfect gas where the mass and pressure is kept constant, the volume vary directly with the absolute temperature.
Charles' Law can be expressed as
V / T = constant                                          (1)
or
V 1 / T 1 = V 2 / T 2 (1b)
V = volume (m 3 , ft 3 ...)
T = absolute temperature (K, R)
Example - Charles' Law
A gas occupies a volume of 2 liter at 0 o C . The volume it occupies at 100 o C can be calculated as
V 2 =  T 2 V 1 / T 1
= (373 K)  (2 liters) / (273 K)
= 2.73 (liters )
Gases and Compressed Air
Air - Volume vs. Temperature
Air volume vs. temperature correction factor compared to Normal Air Conditions.
Boyle's Law (Mariotte's Law)
The volume of an ideal gas vs. pressure.
The Ideal Gas Law
