Boiler Rooms - Sizing
The required area and volume of a boiler room is influenced by the combustion technology used - where combustion and handling of coal requires a lot more space than combustion of gas or oil.
The diagram below can be used to indicate the minimum space required for boilers combustion oil.
• Combustion
Boiler - Efficiency
Combustion gross and net calorific value.
Boilers - Classification
Classification of boilers according the ASME Boiler and Pressure Vessel Code.
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Intermittent Combustion and Boiler Efficiency
Efficiency reduction due to intermittent boiler operation.
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
