Nozzles
Gas flow through nozzles and sonic chokes.
The maximum gas flow through a nozzle is determined by critical pressure.
  • critical pressure ratio is the pressure ratio where the flow is accelerated to a velocity equal to the local velocity of sound in the fluid
Critical flow nozzles are also called sonic chokes. By establishing a shock wave the sonic choke establish a fixed flow rate unaffected by the differential pressure, any fluctuations or changes in downstream pressure. A sonic choke may provide a simple way to regulate a gas flow.
nozzle flow
The ratio between critical pressure and initial pressure for a nozzle can expressed as
pc / p1 = (2 / (n + 1))n / (n - 1)                            (1)
pc = critical pressure (Pa)
p1 = inlet pressure (Pa)
n = index of isentropic expansion or compression - or polytropic constant
For a perfect gas undergoing an adiabatic process the index - n - is the ratio of specific heats - k = cp / cv. There is no unique value for - n. Values for some common gases
  • Steam where most of the process occurs in the wet region : n = 1.135
  • Steam superheated : n = 1.30
  • Air : n = 1.4
  • Methane : n = 1.31
  • Helium : n = 1.667
Example - Air Nozzles and Critical Pressure Ratios
The critical pressure ratio for an air nozzle can be calculated as
pc / p1 = (2 / (1.4 + 1))1.4 / (1.4 - 1)
    = 0.528
Critical pressures for other values of - n:
Air Nozzles - Critical Pressure Ratios
n 1.135 1.300 1.400 1.667
pc/ p1 0.577 0.546 0.528 0.487
Mass Flow through Nozzles
The mass flow through a nozzle with sonic flow where the minimum pressure equals the critical pressure can be expressed as
mc = Ac (n p1 ρ1)1/2 (2 / (n + 1))(n + 1) / 2(n - 1)                                    (2)
mc = mass flow at sonic flow (kg/s)
Ac = nozzle area (m2)
ρ1 = initial density (kg/m3)
