ASTM Standard - Volume 05.06 Gaseous Fuels, Coal and Coke
An overview of ASTM Section 5 - Petroleum Products, Lubricants, and Fossil Fuels - Volume 05.06 Gaseous Fuels, Coal and Coke.
The ASTM Standard
  • Section 5 - Petroleum Products, Lubricants, and Fossil Fuels - Volume 05.06, September 2002 Gaseous Fuels, Coal and Coke
covers gaseous fuels, and coal and coke.
In Gaseous Fuels, tables and practices fix standard procedures for sampling and calculating thermo physical properties. In addition, several tests defines methods for analyzing the properties of gaseous fuels.
In Coal and Coke, tests and practices establish procedures for evaluating properties of coal and coke such as dustiness, moisture content, plastic properties, and Sulphur content.
  • D121-01a Standard Terminology of Coal and Coke
  • D167-93(1999)e1 Standard Test Method for Apparent and True Specific Gravity and Porosity of Lump Coke
  • D197-87(2002) Standard Test Method for Sampling and Fineness Test of Pulverized Coal
  • D291-86(2002) Standard Test Method for Cubic Foot Weight of Crushed Bituminous Coal
  • D293-93(1999) Standard Test Method for the Sieve Analysis of Coke
  • D346-90(1998) Standard Practice for Collection and Preparation of Coke Samples for Laboratory Analysis
  • D388-99e1 Standard Classification of Coals by Rank
  • D409-02 Standard Test Method for Grindability of Coal by the Hardgrove-Machine Method
  • D440-86(2002) Standard Test Method of Drop Shatter Test for Coal
  • D441-86(2002) Standard Test Method of Tumbler Test for Coal
  • D720-91(1999) Standard Test Method for Free-Swelling Index of Coal
  • D1070-85(1998) Standard Test Methods for Relative Density of Gaseous Fuels
  • D1071-83(1998)e1 Standard Test Methods for Volumetric Measurement of Gaseous Fuel Samples
  • D1072-90(1999) Standard Test Method for Total Sulfur in Fuel Gases
  • D1142-95(2000) Standard Test Method for Water Vapor Content of Gaseous Fuels by Measurement of Dew-Point Temperature
  • D1412-02 Standard Test Method for Equilibrium Moisture of Coal at 96 to 97 Percent Relative Humidity and 30�C
  • D1756-96(2000) Standard Test Method for Determination as Carbon Dioxide of Carbonate Carbon in Coal
  • D1757-96(2002) Standard Test Method for Sulfur in Ash from Coal and Coke
  • D1826-94(1998) Standard Test Method for Calorific (Heating) Value of Gases in Natural Gas Range by Continuous Recording Calorimeter
  • D1857-87(2000) Standard Test Method for Fusibility of Coal and Coke Ash
  • D1945-96(2001) Standard Test Method for Analysis of Natural Gas by Gas Chromatography
  • D1946-90(2000) Standard Practice for Analysis of Reformed Gas by Gas Chromatography
  • D1988-91(2000) Standard Test Method for Mercaptans in Natural Gas Using Length-of-Stain Detector Tubes
  • D2013-01 Standard Practice of Preparing Coal Samples for Analysis
  • D2014-97 Standard Test Method for Expansion or Contraction of Coal by the Sole-Heated Oven
  • D2234-00e1 Standard Practice for Collection of a Gross Sample of Coal
  • D2361-95(2001) Standard Test Method for Chlorine in Coal
  • D2492-90(1998) Standard Test Method for Forms of Sulfur in Coal
  • D2639-98 Standard Test Method for Plastic Properties of Coal by the Constant-Torque Gieseler Plastometer
  • D2797-85(1999) Standard Practice for Preparing Coal Samples for Microscopical Analysis by Reflected Light
  • D2798-99 Standard Test Method for Microscopical Determination of the Reflectance of Vitrinite in a Polished Specimen of Coal
  • D2799-99 Standard Test Method for Microscopical Determination of Volume Percent of Physical Components of Coal
  • D2961-01a Standard Test Method for Single-Stage Total Moisture Less than 15% in Coal Reduced to 2.36-mm (No. 8 Sieve) Topsize
  • D3038-93(1999) Standard Test Method for Drop Shatter Test for Coke
  • D3172-89(2002) Standard Practice for Proximate Analysis of Coal and Coke
  • D3173-00 Standard Test Method for Moisture in the Analysis Sample of Coal and Coke
  • D3174-00 Standard Test Method for Ash in the Analysis Sample of Coal and Coke from Coal
  • D3175-01 Standard Test Method for Volatile Matter in the Analysis Sample of Coal and Coke
  • D3176-89(2002) Standard Practice for Ultimate Analysis of Coal and Coke
  • D3177-89(2002) Standard Test Methods for Total Sulfur in the Analysis Sample of Coal and Coke
  • D3178-89(1997) Standard Test Methods for Carbon and Hydrogen in the Analysis Sample of Coal and Coke
  • D3179-89(2002) Standard Test Methods for Nitrogen in the Analysis Sample of Coal and Coke
  • D3180-89(2002) Standard Practice for Calculating Coal and Coke Analyses from As-Determined to Different Bases
  • D3302-02 Standard Test Method for Total Moisture in Coal
  • D3402-93(2001) Standard Test Method for Tumbler Test for Coke
  • D3588-98 Standard Practice for Calculating Heat Value, Compressibility Factor, and Relative Density of Gaseous Fuels
  • D3682-01 Standard Test Method for Major and Minor Elements in Combustion Residues from Coal Utilization Processes
  • D3683-94(2000) Standard Test Method for Trace Elements in Coal and Coke Ash by Atomic Absorption
  • D3684-01 Standard Test Method for Total Mercury in Coal by the Oxygen Bomb Combustion/Atomic Absorption Method
  • D3761-96(2002) Standard Test Method for Total Fluorine in Coal by the Oxygen Bomb Combustion/Ion Selective Electrode Method
  • D3956-93(1998) Standard Specification for Methane Thermophysical Property Tables
  • D3984-93(1998) Standard Specification for Ethane Thermophysical Property Tables
  • D3997-97 Standard Practice for Preparing Coke Samples for Microscopical Analysis by Reflected Light
  • D4084-94(1999) Standard Test Method for Analysis of Hydrogen Sulfide in Gaseous Fuels (Lead Acetate Reaction Rate Method)
  • D4150-00 Standard Terminology Relating to Gaseous Fuels
  • D4182-97 Standard Practice for Evaluation of Laboratories Using ASTM Procedures in the Sampling and Analysis of Coal and Coke
  • D4208-88(2002) Standard Test Method for Total Chlorine in Coal by the Oxygen Bomb Combustion/Ion Selective Electrode Method
  • D4239-02 Standard Test Methods for Sulfur in the Analysis Sample of Coal and Coke Using High Temperature Tube Furnace Combustion Methods
  • D4326-01 Standard Test Method for Major and Minor Elements in Coal and Coke Ash By X-Ray Fluorescence
  • D4362-93(1998)e1 Standard Specification for Propane Thermophysical Property Tables
  • D4371-91(1998) Standard Test Method for Determining the Washability Characteristics of Coal
  • D4468-85(2000) Standard Test Method for Total Sulfur in Gaseous Fuels by Hydrogenolysis and Rateometric Colorimetry
  • D4596-99 Standard Practice for Collection of Channel Samples of Coal in a Mine
  • D4606-95(2000) Standard Test Method for Determination of Arsenic and Selenium in Coal by the Hydride Generation/Atomic Absorption Method
  • D4621-99 Standard Guide for Quality Management in an Organization That Samples or Tests Coal and Coke
  • D4650-93(1998) Standard Specification for Normal Butane Thermophysical Property Tables
  • D4651-93(1998) Standard Specification for Isobutane Thermophysical Property Tables
  • D4702-97 Standard Guide for Inspecting Crosscut, Sweep-Arm, and Auger Mechanical Coal-Sampling Systems for Conformance with Current ASTM Standards
  • D4749-87(2002) Standard Test Method for Performing the Sieve Analysis of Coal and Designating Coal Size
  • D4784-93(1998) Standard Specification for LNG Density Calculation Models
  • D4810-88(1999) Standard Test Method for Hydrogen Sulfide in Natural Gas Using Length-of-Stain Detector Tubes
  • D4888-88(1999) Standard Test Method for Water Vapor in Natural Gas Using Length-of-Stain Detector Tubes
  • D4891-89(2001) Standard Test Method for Heating Value of Gases in Natural Gas Range by Stoichiometric Combustion
  • D4915-96 Standard Guide for Manual Sampling of Coal from Tops of Railroad Cars
  • D4916-97 Standard Practice for Mechanical Auger Sampling
  • D4984-89(1999) Standard Test Method for Carbon Dioxide in Natural Gas Using Length-of-Stain Detector Tubes
  • D5016-98 Standard Test Method for Sulfur in Ash from Coal, Coke, and Residues from Coal Combustion Using High-Temperature Tube Furnace Combustion Method with Infrared Absorption
  • D5061-92(1997) Standard Test Method for Microscopical Determination of Volume Percent of Textural Components in Metallurgical Coke
  • D5114-90(1998) Standard Test Method for Laboratory Froth Flotation of Coal in a Mechanical Cell
  • D5142-02 Standard Test Methods for Proximate Analysis of the Analysis Sample of Coal and Coke by Instrumental Procedures
  • D5192-99 Standard Practice for Collection of Coal Samples from Core
  • D5263-93(2001) Standard Test Method for Determining the Relative Degree of Oxidation in Bituminous Coal by Alkali Extraction
  • D5287-97 Standard Practice for Automatic Sampling of Gaseous Fuels
  • D5341-99 Standard Test Method for Measuring Coke Reactivity Index (CRI) and Coke Strength After Reaction (CSR)
  • D5373-93(2002) Standard Test Methods for Instrumental Determination of Carbon, Hydrogen, and Nitrogen in Laboratory Samples of Coal and Coke
  • D5454-93(1999) Standard Test Method for Water Vapor Content of Gaseous Fuels Using Electronic Moisture Analyzers
  • D5503-94(1999) Standard Practice for Natural Gas Sample-Handling and Conditioning Systems for Pipeline Instrumentation
  • D5504-01 Standard Test Method for Determination of Sulfur Compounds in Natural Gas and Gaseous Fuels by Gas Chromatography and Chemiluminescence
  • D5515-97 Standard Test Method for Determination of the Swelling Properties of Bituminous Coal Using a Dilatometer
  • D5671-95(2001) Standard Practice for Polishing and Etching Coal Samples for Microscopical Analysis by Reflected LightD5865-02 Standard Test Method for Gross Calorific Value of Coal and Coke
  • D5954-98 Standard Test Method for Mercury Sampling and Measurement in Natural Gas by Atomic Absorption Spectroscopy
  • D5987-96(2002) Standard Test Method for Total Fluorine in Coal and Coke by Pyrohydrolytic Extraction and Ion Selective Electrode or Ion Chromatograph Methods
  • D6172-98e1 Standard Test Method for Determining the Volume of Bulk Materials Using Contours or Cross Sections Created by Direct Operator Compilation Using Photogrammetric Procedures
  • D6228-98 Standard Test Method for Determination of Sulfur Compounds in Natural Gas and Gaseous Fuels by Gas Chromatography and Flame Photometric Detection
  • D6273-98 Standard Test Methods for Natural Gas Odor Intensity
  • D6315-98e1 Standard Practice for Manual Sampling of Coal from Tops of Barges
  • D6316-00 Standard Test Method for Determination of Total, Combustible and Carbonate Carbon in Solid Residues from Coal and Coke
  • D6347/D6347M-99 Standard Test Method for Determination of Bulk Density of Coal Using Nuclear Backscatter Depth Density Methods
  • D6349-01 Standard Test Method for Determination of Major and Minor Elements in Coal, Coke, and Solid Residues from Combustion of Coal and Coke by Inductively Coupled Plasma�Atomic Emission Spectrometry
  • D6350-98 Standard Test Method for Mercury Sampling and Analysis in Natural Gas by Atomic Fluorescence Spectroscopy
  • D6357-00a Test Methods for Determination of Trace Elements in Coal, Coke, & Combustion Residues from Coal Utilization Processes by Inductively Coupled Plasma Atomic Emission, Inductively Coupled Plasma Mass, & Graphite Furnace Atomic Absorption Spectrometrics
  • D6414-01 Standard Test Method for Total Mercury in Coal and Coal Combustion Residues by Acid Extraction or Wet Oxidation/Cold Vapor Atomic Absorption
  • D6518-01 Standard Practice for Bias Testing a Mechanical Coal Sampling System
  • D6542-00 Standard Practice for Tonnage Calculation of Coal in a Stockpile
  • D6543-00e1 Standard Guide to the Evaluation of Measurements Made by On-Line Coal Analyzers
  • D6609-01 Standard Guide for Part-Stream Sampling of Coal
  • D6610-01a Standard Practice for Manual Sampling Coal from Surfaces of a Stockpile
  • D6721-01 Standard Test Method for Determination of Chlorine in Coal by Oxidative Hydrolysis Microcoulometry
  • D6722-01 Standard Test Method for Total Mercury in Coal and Coal Combustion Residues by Direct Combustion Analysis
  • D6796-02 Standard Practice for Production of Coal, Coke and Coal Combustion Samples for Interlaboratory Studies
