Electric Circuits Voltage Drop
Ohm's law and voltage drop in electric circuits.
Voltage drop in an electric circuit can be calculated using Ohm's law as
U = R I (1)
U = voltage drop (volts, V)
R = electrical resistance in the electric circuit (ohms, Ω)
I = current (amps, A)
Example - Voltage Drop
Voltage drop in a 100 ft power line:
The electric resistance in the circuit can be calculated
R = (1.02 Ω/1000 ft) (100 ft) 2
= 0.204 Ω
The voltage drop in the circuit can be calculated with (1)
U = ( 0.204 Ω ) (10 amps)
= 2.04 volts
Circular mils and Voltage drop
Voltage drop can also be calculated using mils like
U = K P L I / A                       (2)
K = specific resistivity ( Ω - circular mils/foot)
P = phase constant = 2 (for single phase) = 1.732 (for three phase)
L =  wire length (ft)
A = wire area ( circular mils )
Specific electric resistivity for different types of wire materials
  • Solid Copper, K = 11 (temp 77 oF - 121 oF), K = 12 (temp 122 oF - 167 oF)
  • Solid Aluminum, K = 18 (temp 77 oF - 121 oF), K = 20 (temp 122 oF - 167 oF)
  • Stranded Copper, K = 11 (temp 77 oF - 121 oF), K = 12 (temp 122 oF - 167 oF)
  • Stranded Aluminum, K = 19 (temp 77 oF - 121 oF), K = 20 (temp 122 oF - 167 oF)
Example - Specific resistivity and Voltage Drop
With values from the example above the voltage drop can be calculated as
U = (11 ohm - circular mils/foot) 2 (100 ft) (10 A) / (10400 mils)
= 2.11 V
Copper Conductor - Voltage Drop Table
The voltage drop in a copper conductor can be estimated with
U = f I L                          (3)
f = factor from table below
I = current (amps)
L = conductor length (ft)
SizeFactor
- f -
AWG Metric
mm2
Single-phase3-phase
14 2.08 0.476 0.42
12 3.31 0.313 0.26
10 5.26 0.196 0.17
8 8.37 0.125 0.11
6 13.3 0.0833 0.071
4 21.2 0.0538 0.046
3 0.0431 0.038
2 33.6 0.0323 0.028
1 42.4 0.0323 0.028
1/0 53.5 0.0269 0.023
2/0 67.4 0.0222 0.020
3/0 85.0 0.019 0.016
4/0 107.2 0.0161 0.014
250 0.0147 0.013
300 0.0131 0.011
350 0.0121 0.011
400 0.0115 0.009
500 0.0101 0.009
  • Electrical
  • The Engineering ToolBox (2009). Electric Circuits Voltage Drop. [online] Available at: https://www.engineeringtoolbox.com/voltage-drop-d_1550.html [Accessed Day Month Year].
