AWG - American Wire Gauge Converting Chart
American Wire Gauge (AWG) vs. cross sectional area converter.
AWG - American Wire Gauge - is an U.S. standard for wire conductor size. The "gauge" is related to the diameter of the wire.
  • larger "gauge" -> smaller diameter and thinner wire
awg wire gauge
The AWG standard includes copper, aluminum and other wire materials. Typical household copper wiring is AWG number 12 or 14. Telephone wire is usually 22, 24, or 26. The higher the gauge number, the smaller the diameter and the thinner the wire.
The table below can be used to convert American Wire Gauge (AWG) to square mm cross sectional area.
AWG - American Wire Gauges - Diameters and Areas
American Wire Gauge
(#AWG)
Diameter
(inches)
Diameter
(mm)
Cross Sectional Area
(mm2)
0000 (4/0) 0.460 11.7 107
000 (3/0) 0.410 10.4 85.0
00 (2/0) 0.365 9.27 67.4
0 (1/0) 0.325 8.25 53.5
1 0.289 7.35 42.4
2 0.258 6.54 33.6
3 0.229 5.83 26.7
4 0.204 5.19 21.1
5 0.182 4.62 16.8
6 0.162 4.11 13.3
7 0.144 3.67 10.6
8 0.129 3.26 8.36
9 0.114 2.91 6.63
10 0.102 2.59 5.26
11 0.0907 2.30 4.17
12 0.0808 2.05 3.31
13 0.0720 1.83 2.63
14 0.0641 1.63 2.08
15 0.0571 1.45 1.65
16 0.0508 1.29 1.31
17 0.0453 1.15 1.04
18 0.0403 1.02 0.82
19 0.0359 0.91 0.65
20 0.0320 0.81 0.52
21 0.0285 0.72 0.41
22 0.0254 0.65 0.33
23 0.0226 0.57 0.26
24 0.0201 0.51 0.20
25 0.0179 0.45 0.16
26 0.0159 0.40 0.13
Note! - the diameter of a solid and stranded wire with the same AWG is not identical. The diameter of a stranded wire is larger than the diameter of a solid wire.
American Wire Gauge - AWG, Imperial and Metric Units
Download and print AWG chart
  • Electrical
  • The Engineering ToolBox (2004). AWG - American Wire Gauge Converting Chart. [online] Available at: https://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html [Accessed Day Month Year].
