Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
  • Conductors are materials with loosely attached valence electrons - electrons can drift freely between the atoms
  • Insulators have structures where the electrons are bound to the atoms by ionic or covalent bonds - almost no current can flow
  • Semiconductors are insulating materials where the bonds can be broken with applied voltage - electrons can be released and moved from one vacated valence site to another.
Electrical conductivity or specific conductivity is the measure of a material's ability to conduct electric current. Conductivity is the reciprocal (inverse) of electrical resistivity .
Electrical conductivity is defined as the ratio of the current density to the electric field strength and can be expressed as
σ = J / E                          (1)
σ = electrical conductivity (1/ohms m, 1/ Ω m, siemens/m, S/m, mho/m)
J = current density (amps/m2)
E = electric field strength (volts/m)
One siemens - S - is equal to the reciprocal of one ohm and is also referred to as one mho.
Electrical Conductivity of some Common Materials
ProductElectrical Conductivity
- σ -
(1/Ω m, S/m, mho/m)
Aluminum 37.7 106
Beryllium 31.3 106
Cadmium 13.8 106
Calcium 29.8 106
Chromium 7.74 106
Cobalt 17.2 106
Copper 59.6 106
Copper - annealed 58.0 106
Gallium 6.78 106
Gold 45.2 106
Iridium 19.7 106
Iron 9.93 106
Indium 11.6 106
Lithium 10.8 106
Magnesium 22.6 106
Molybdenum 18.7 106
Nickel 14.3 106
Niobium 6.93 106
Osmium 10.9 106
Palladium 9.5 106
Platinum 9.66 106
Potassium 13.9 106
Rhenium 5.42 106
Rhodium 21.1 106
Rubidium 7.79 106
Ruthenium 13.7 106
Silver 63 106
Sodium 21 106
Strontium 7.62 106
Tantalum 7.61 106
Technetium 6.7 106
Thallium 6.17 106
Thorium 6.53 106
Tin 9.17 106
Tungsten 18.9 106
Zinc 16.6 106
Seawater 4.5  - 5.5
Water - Drinking 0.0005 - 0.05
Water - Deionized 5.5 10-6
  • 1 S/m = 104 μS/cm = mho/m
  • 1 S/cm = 10-2 S/m
  • 1 1/Ω m = S/m = 3.28 1/Ω ft = 3.28 S/ft
Electrical Conductivity of Elements relative to Silver
ElementElectrical Conductivity relative to Silver
Silver 100.0
Copper 94.6
Gold 71.7
Aluminum 59.8
Beryllium 49.7
Calcium 47.3
Magnesium 35.9
Rhodium 33.5
Sodium 33.0
Barium 30.6
Tungsten 30.0
Molybdenum 29.7
Cobalt 27.3
Zinc 26.3
Nickel 22.6
Cadmium 21.9
Ruthenium 21.7
Cesium 20.0
Indium 18.4
Osmium 17.3
Lithium 17.1
Uranium 16.5
Manganese 15.8
Iron 15.8
Platinum 15.3
Palladium 15.1
Tin 14.6
Titanium 13.7
Iridium 13.5
Rubidium 12.4
Chromium 12.3
Tantalum 12.1
Steel 12.0
Thallium 9.8
Lead 8.4
Columbium 5.1
Vanadium 5.0
Arsenic 4.9
Antimony 3.6
Mercury 1.8
Bismuth 1.4
Tellurium 0.0
Electrical Conductivity of Highly Purified Water
Electrical conductivity of highly purified water
Electrical Resistivity
Conductivity is the reciprocal (inverse) of electrical resistivity. Electrical resistivity can be expressed as
ρ = 1 / σ (2)
ρ = electrical resistivity (ohm m2/m, ohm m)
Resistance of a Conductor
The resistance for a conductor can be expressed as
R = ρ l / A                      (3)
R = resistance (ohms, Ω)
l = length of conductor (m)
A = cross sectional area of conductor (m2)
Example - Resistance of a Wire
The resistance of 1000 m copper wire gauge #10 with cross sectional area 5.26 mm2 can be calculated as
R = (1.724 x 10 -8 ohm m2/m) (1000 m) / (( 5.26 mm2) (10-6 m2/mm2))
= 3.2 ohm
Resistivity and Conductivity Conversion
Grains/gal
as CaCO3
ppm
as CaCO3
ppm
NaCl
Conductivity
μmho/cm
Resistivity
MΩ/cm
99.3 1700 2000 3860 0.00026
74.5 1275 1500 2930 0.00034
49.6 850 1000 1990 0.00050
24.8 425 500 1020 0.00099
9.93 170 200 415 0.0024
7.45 127 150 315 0.0032
4.96 85.0 100 210 0.0048
2.48 42.5 50 105 0.0095
0.992 17.0 20 42.7 0.023
0.742 12.7 15 32.1 0.031
0.496 8.50 10 21.4 0.047
0.248 4.25 5.0 10.8 0.093
0.099 1.70 2.0 4.35 0.23
0.074 1.27 1.5 3.28 0.30
0.048 0.85 1.00 2.21 0.45
0.025 0.42 0.50 1.13 0.88
0.0099 0.17 0.20 0.49 2.05
0.0076 0.13 0.15 0.38 2.65
0.0050 0.085 0.10 0.27 3.70
0.0025 0.042 0.05 0.16 6.15
0.00099 0.017 0.02 0.098 10.2
0.00070 0.012 0.015 0.087 11.5
0.00047 0.008 0.010 0.076 13.1
0.00023 0.004 0.005 0.066 15.2
0.00012 0.002 0.002 0.059 16.9
  • grains/gal = 17.1 ppm CaCO3
Electrical Conductivity of Aqueous Solutions
Electrical conductivity of aqueous solutions like
  • NaOH 4 - Caustic soda
  • NH 4 Cl - Ammonium chloride, Sal ammoniac
  • NaCl2- Common salt
  • NaNO3 - Sodium nitrate, Chilean saltpetre
  • CaCl2- Calcium chloride
  • ZnCl2- Zinc chloride
  • NaHCO3 - Sodium bicarconate, baking soda
  • Na2CO3 - Sodium carbonate, soda ash
  • CuSO 4 - Copper sulfate, blue vitriol
  • Electrical
  • The Engineering ToolBox (2008). Electrical Conductivity - Elements and other Materials. [online] Available at: https://www.engineeringtoolbox.com/conductors-d_1381.html [Accessed Day Month Year].
