Electrical Parallel Circuits
In a parallel circuit there is more than one path the electrons can flow.
The Parallel Circuit Rules:
  1. The total current in parallel circuit is equal to the sum of the currents in all the branches of the circuit.
  2. The total voltage across a parallel circuit is equal to the voltage across any of the branches in the circuit.
  3. The total resistance of a parallel circuit is calculated by using Ohm's law on the voltage and current of the whole circuit.
The sum of currents in a parallel network can be calculated as
I = I1 + I2+ ... + I n (1)
I n = parallel current (amps)
I = sum of currents (amps)
The total resistance in a parallel circuit can be calculated as
1 / R = 1 / R1 + 1 / R2+ ... + 1 / R n (2)
R n = parallel resistance (ohms, Ω)
R = total resistance in the parallel network (ohms, Ω)
Example - Parallel Network
The total resistance in a network with three resistors R1 = 10 Ω, R2= 20 Ω  and R3 = 30 Ω can be calculated as
1 / R = 1 / (10 Ω) + 1 / (20 Ω) + 1 / (30 Ω)
= 0.183 (1/Ω)
R = 1 / 0.183
= 5.46 (Ω)
Connected to a 12 V battery the sum of currents can be calculated
I = U / R
=  (12 V) / (5.46 Ω)
= 2.2 Amps)
The current through each resistor can be calculated as
I1 = U / R1
=  (12 V) / (10 Ω)
= 1.2 (Amps)
I2= U / R2
=  (12 V) / (20 Ω)
= 0.6 (Amps)
I3 = U / R3
=  (12 V) / (30 Ω)
= 0.4 (Amps)
Resistors in Parallel and resulting Resistance
Two resistors in parallel - resistance ranging 1 - 100 ohm
R2
( Ω )
Resulting Resistance (Ω)
R1 ( Ω )
1 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68
1 0.5 0.6 0.69 0.77 0.83 0.87 0.91 0.93 0.95 0.97 0.98 0.99
1.5 0.6 0.75 0.89 1.03 1.14 1.22 1.30 1.36 1.40 1.43 1.45 1.46
2.2 0.69 0.89 1.1 1.32 1.50 1.66 1.82 1.92 2.0 2.06 2.10 2.13
3.3 0.77 1.03 1.32 1.65 1.94 2.22 2.48 2.70 2.87 3.00 3.08 3.14
4.7 0.83 1.14 1.50 1.94 2.35 2.78 3.20 3.58 3.87 4.12 4.27 4.39
6.8 0.87 1.22 1.66 2.22 2.78 3.40 4.05 4.68 5.19 5.64 5.94 6.18
10 0.91 1.30 1.82 2.48 3.20 4.05 5.0 6.0 6.9 7.7 8.3 8.7
15 0.93 1.36 1.92 2.70 3.58 4.68 6.0 7.50 8.9 10.3 11.4 12.2
22 0.95 1.40 2.00 2.87 3.87 5.19 6.9 8.9 11.0 13.2 15.0 16.6
33 0.97 1.43 2.06 3.0 4.12 5.64 7.7 10.3 13.2 16.5 19.4 22.2
47 0.98 1.45 2.1 3.08 4.27 5.94 8.3 11.4 15.0 19.4 23.5 27.8
68 0.99 1.46 2.13 3.14 4.39 6.18 8.7 12.2 16.6 22.2 27.8 34.0
Resistors in parallel - resulting resistance chart
Download and print Resistors in parallel chart
  • Electrical
  • The Engineering ToolBox (2009). Electrical Parallel Circuits. [online] Available at: https://www.engineeringtoolbox.com/parallel-networks-d_1385.html [Accessed Day Month Year].
