Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
Kirchhoff's Current Law
Also called Kirchhoff's first law, Kirchhoff's point rule, Kirchhoff's junction rule (or nodal rule) or Kirchhoff's first rule.
kirchhoff's laws current
At any junction in an electric circuit the total current flowing towards the junction or node is equal to the total current flowing away from the junction.
Kirchhoff's Current Law can be expressed as
 Σ I = I1 + I2 + .. + In = 0              (1)
I = currents (amps)
In general - current toward the junction is positive and current flowing away from the junction is negative.
Example - Kirchhoff's Current Law
The currents in the figure above is I1 = 0.1 A, I2 = 0.2 A, I3 = 0.1 A, I4 = - 0.05 A, I5 = -0.15 A.
I6 can be calculated by using Kirchhoff's current law
(0.1 A) + (0.2 A) + (0.1 A) + (- 0.05 A) + (-0.15 A) + I6 = 0
or
I6 = -((0.1 A) + (0.2 A) + (0.1 A) + (- 0.05 A) + (-0.15 A))
   = -0.2 A
Kirchhoff's Voltage Law
Also called Kirchhoff's second law, Kirchhoff's loop (or mesh) rule, or Kirchhoff's second rule.
In a closed loop in a network the sum of the voltage drops or potential differences around the loop is zero.
Kirchhoff's Voltage Law can be expressed as
 Σ U = U1 + U2 + .. + Un = 0                       (2)
U = voltage drop or potential difference (volts)
In a schematic diagram voltage can be measured positive clockwise or anticlockwise.
  • Electrical
  • The Engineering ToolBox (2008). Kirchhoff's Voltage and Current Laws . [online] Available at: https://www.engineeringtoolbox.com/kirchhoff-laws-d_1386.html [Accessed Day Month Year].
