Current Divider - Online Calculator
An electric current divider outputs a current that is a fraction of the input current.
A current divider is a linear circuit that produces an output current that is a fraction of the input current.
electric circuit current divider
Current is split between the branches of the divider. The total resistance in the electrical circuit can calculated
R T = R1 R2/ (R1 + R2)      (1)
R T = total resistance (ohms, Ω)
R n = resistance in branch n (ohms, Ω )
The voltage difference across the circuit
U = I R T
= I R1 R2/ (R1 + R2)   (2)
U = electrical potential (volts, V)
I = total current through the circuit (amps, A)
Split current I1 can be calculated
I1 = U / R1
= (I R1 R2/ (R1 + R2) ) / R1
=   I R2/ (R1 + R2)     (3)
Split current I2 can be calculated
I2= U / R2
= (I R1 R2/ (R1 + R2) ) / R2
=   I R1 / (R1 + R2)     (4)
Example - Current Divider
The total resistance in a current divider with supply voltage 3.3 V and resistor R1 = 220 ohm and resistor R2=  47 ohm can be calculated as
R T = ( 220 ohm ) ( 47 ohm ) / (( 220 ohm ) + ( 47 ohm ))
= 38.7 ohm
The total current through the current divider can be calculated
I = (3.3 V) / (38.7 ohm)
= 0.085 amps
= 85 mA
The current through resistor R1 can be calculated
I1 = (3.3 V) / (220 ohm)
= 0.015 amps
= 15 mA
The current through resistor R2 can be calculated
I2= (3.3 V) / (47 ohm)
= 0.070 amps
= 70 mA
R - total resistance (ohms)
I1 - split current (amps)
I2- split current (amps)
I - total current (amps)
  • Electrical
  • The Engineering ToolBox (2012). Current Divider - Online Calculator. [online] Available at: https://www.engineeringtoolbox.com/current-division-d_1837.html [Accessed Day Month Year].
