Electric Wire - Calculating Cross-Section Areas
Calculate single and bunched electric wire cross-section area and diameter.
Cross-Section Area of Single Wire
The cross-section area of a round single wire can be calculated as
A = D2π / 4
= 0.7854 D2
A = cross-section area (mm2, in2)
D = diameter (mm, in)
Cross-Section Area Calculator - Single Wire
Cross-Section Area of Bunched Wire
The cross-section area of bunched wires can be calculated as
A = n d2π / 4
= 0.7854 n d2
n = number of wires
d = single wire diameter (mm, in)
Cross-Section Area Calculator - Multiple Wires
Diameter of a Single Wire Cross-Section Area
The diameter of a single wire cross-section area can be calculated as
D = (A 4 / π ) 1/2
= (1.2732 A ) 1/2
  • Electrical
  • The Engineering ToolBox (2014). Electric Wire - Calculating Cross-Section Areas. [online] Available at: https://www.engineeringtoolbox.com/electric-wire-calculation-d_1880.html [Accessed Day Month Year].
