Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Typical flow coefficients - Cv - and flow factors - Kv - for diaphragm straight through flanged cast iron valves of "Saunders" type:
Valve SizeUnlinedRubber LinedGlass/Plastic Lined
DNInchesCvKvCvKvCvKv
15 1/2 9 7 9 8
25 1 38 33 31 26 39 34
32 1 1/4 56 48 46 39 58 50
40 1 1/2 75 65 66 57 79 68
50 2 128 110 107 92 138 119
65 2 1/2 238 205 195 168 254 219
80 3 330 284 264 228 342 295
100 4 588 507 480 414 618 533
125 5 924 797 720 621 960 828
150 6 1 680 1 448 1 260 1 086 1 800 1 552
200 8 2 580 2 224 2 196 1 893 2 724 2 348
250 10 4 020 3 466 3 420 2 948 4 296 3 703
300 12 6 060 5 224 4 884 4 210
350 14 10 300 8 879 9 950 8 578
The opening and closing characteristic of the valves are close to positive linear:
  • closing a valve to 80% - reduces the flow coefficient to approximately 85%
  • closing a valve to 50% - reduces the flow coefficient to approximately 60%
This close to linear characteristic make the valves suited for adjustment and balancing operations. In addition the lined versions are able to resist wear and tear and rough environments and processes.
  • Control Valve Sizing
  • Design of Control and Safety Valves
  • Piping Systems
  • The Engineering ToolBox (2003). Straight Through Diaphragm Valves - Flow Coefficients. [online] Available at: https://www.engineeringtoolbox.com/saunders-valves-flow-coefficients-d_226.html [Accessed Day Month Year].
