Control Valves and Equipment
Sizing and dimensions of control valves & equipment in steam and condensate systems
Back Pressure and Steam Trap Capacity
Back pressure in a condensate systems will reduce the steam trap capacity
Control Valve Sizing for Steam Systems
Calculating steam control valves
Flow Coefficient - Cv - Formulas for Liquids, Steam and Gases - Online Calculators
The flow coefficient - Cv - is important for proper design of control valves
Flow Coefficient Cv and Flow Factor Kv
Comparing flow coefficient Cv with flow factor Kv
Safety Steam Valve Installation Guide
Guidelines to safety steam valve installation
Safety Valve Standards
An survey of international safety valve standards. The most common used standards in Germany, UK, USA, France, Japan, Australia and Europe
Safety Valves and Relief Capacity
Maximum safety valves free air relief capacity
Safety Valves in High Pressure Steam Systems
Sizing safety valves after boiler output power in high pressure systems (kW and Btu/hr)
Safety Valves in Low Pressure Steam Systems
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr)
Safety Valves in Saturated Steam Systems
Calculate relief valves in saturated steam systems
Sizing and Selection Control Valves
Select and size the control valve that most closely matches the process requirements
Steam Control Valves - Calculating Kv Values
Design of steam control valves and their Kv values
Steam Flow Through Orifices
Steam flow through orifices - steam pressure ranging 2 - 300 psi
Steam Trap Safety Factor
Selection of steam traps and safety factors
Steam Trap Selection Guide
A steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps
