Valve Selection Guide
Applications guide for selecting valves.
The suitability of a valve for a particular application is decided by the materials used in relation to the conveyed fluid as well as its mechanical design. The table below can be used as a valve selection guide.
Conveyed FluidNature of FluidValve FunctionType of Disc
Liquid Neutral
(Water, Oil, etc)
On/Off Gate
Rotary ball
Plug
Diaphragm
Butterfly
Plug gate
Control valve, modulating Globe
Butterfly
Plug gate
Diaphragm
Needle
Corrosive
(Acid, alkaline etc.)
On/Off Gate
Plug gate
Rotary ball
Plug
Diaphragm
Butterfly
Diaphragm
Butterfly
Plug gate
Hygienic
(Food, beverages, drugs etc)
On/Off Butterfly
Diaphragm
Control valve, modulating Butterfly
Diaphragm
Squeeze
Pinch
Slurry On/Off Rotary ball
Butterfly
Diaphragm
Plug
Pinch
Squeeze
Diaphragm
Squeeze
Pinch
Gate
Fibrous Suspensions On/Off,
Gate
Diaphragm
Squeeze
Pinch
Gas Neutral
(Air, Steam etc)
On/Off Gate
Globe
Rotary ball
Plug
Diaphragm
Needle
Butterfly
Diaphragm
Gate
Corrosive
(Acid vapors, chlorine etc.)
On/Off Butterfly
Rotary ball
Diaphragm
Plug
Globe
Needle
Diaphragm
Vacuum On/Off Gate
Globe
Rotary ball
Butterfly
Solids Abrasive Powder
(Silica, etc)
On/Off,
Pinch
Squeeze
Spiral sock
Lubricating powder (graphite, talcum, etc On/Off,
Pinch
Gate
Spiral sock
Squeeze
  • Control Valve Sizing
  • Design of Control and Safety Valves
  • International Valve Standards
    International valve standards for piping systems.
  • Piping Systems
  • The Engineering ToolBox (2003). Valve Selection Guide. [online] Available at: https://www.engineeringtoolbox.com/valve-selection-guide-d_35.html [Accessed Day Month Year].
