ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards.
ASTM International - American Society for Testing and Materials - valve standards:
  • ASTM A126-04
    Standard Specification for Gray Iron Castings for Valves, Flanges, and Pipe Fittings
  • ASTM A182/A182M-04
    Standard Specification for Forged or Rolled Alloy-Steel Pipe Flanges, Forged Fittings, and Valves and Parts for High-Temperature Service
  • ASTM A338
    Standard Specification for Malleable Iron Flanges, Pipe Fittings, and Valve Parts for Railroad, Marine, and Other Heavy Duty Service at Temperatures Up to 650�F (345�C)
  • ASTM A522/A522M-01
    Standard Specification for Forged or Rolled 8 and 9% Nickel Alloy Steel Flanges, Fittings, Valves, and Parts for Low-Temperature Service
  • ASTM A694/A694M-03
    Standard Specification for Carbon and Alloy Steel Forgings for Pipe Flanges, Fittings, Valves, and Parts for High-Pressure Transmission Service
  • ASTM A961-04
    Standard Specification for Common Requirements for Steel Flanges, Forged Fittings, Valves, and Parts for Piping Applications
  • ASTM A988/A988M
    Standard Specification for Hot Isostatically-Pressed Stainless Steel Flanges, Fittings, Valves, and Parts for High Temperature Service
  • ASTM A989/A989M
    Standard Specification for Hot Isostatically-Pressed Alloy Steel Flanges, Fittings, Valves, and Parts for High Temperature Service
  • ASTM B61-2
    Standard Specification for Steam or Valve Bronze Castings
  • ASTM B763
    Standard Specification for Copper Alloy Sand Castings for Valve Application
  • ASTM B834
    Standard Specification for Pressure Consolidated Powder Metallurgy Iron-Nickel-Chromium-Molybdenum (UNS N08367) and Nickel-Chromium-Molybdenum-Columbium (Nb) (UNS N06625) Alloy Pipe Flanges, Fittings, Valves, and Parts
  • ASTM C1129
    Standard Practice for Estimation of Heat Savings by Adding Thermal Insulation to Bare Valves and Flanges
  • ASTM F885
    Standard Specification for Envelope Dimensions for Bronze Globe Valves NPS 1/4 to 2
  • ASTM F992
    Standard Specification for Valve Label Plates
  • ASTM F993
    Standard Specification for Valve Locking Devices
  • ASTM F1020
    Standard Specification for Line-Blind Valves for Marine Applications
  • ASTM F1030
    Standard Practice for Selection of Valve Operators
  • ASTM F1098
    Standard Specification for Envelope Dimensions for Butterfly Valves-NPS 2 to 24
  • ASTM F1271
    Standard Specification for Spill Valves for Use in Marine Tank Liquid Overpressure Protections Applications
  • ASTM F1370
    Standard Specification for Pressure-Reducing Valves for Water Systems, Shipboard
  • ASTM F1394
    Standard Test Method for Determination of Particle Contribution from Gas Distribution System Valves
  • ASTM F1565
    Standard Specification for Pressure-Reducing Valves for Steam Service
  • ASTM F1792
    Standard Specification for Special Requirements for Valves Used in Gaseous Oxygen Service
  • ASTM F1793
    Standard Specification for Automatic Shut-Off Valves (Also Known as Excess Flow Valves, EFV) for Air Or Nitrogen Service
  • ASTM F1794
    Standard Specification for Hand-Operated, Globe-Style Valves for Gas (Except Oxygen Gas), and Hydraulic Systems
  • ASTM F1795
    Standard Specification for Pressure-Reducing Valves for Air or Nitrogen Systems
  • ASTM F1802
    Standard Test Method for Performance Testing of Excess Flow Valves
  • ASTM F1970
    Standard Specification for Special Engineered Fittings, Appurtenances or Valves for use in Poly (Vinyl Chloride) (PVC) or Chlorinated Poly (Vinyl Chloride) (CPVC) Systems
  • ASTM F1985
    Standard Specification for Pneumatic-Operated, Globe-Style, Control Valves
  • ASTM F2138
    Standard Specification for Excess Flow Valves for Natural Gas Service
  • ASTM F2215
    Standard Specification for Balls, Bearings, Ferrous and Nonferrous for Use in Bearings, Valves, and Bearing Applications
  • ASTM F2324
    Standard Test Method for Prerinse Spray Valves
