DIN - Valve Standards
An overview of DIN - Deutsches Institut für Normung - valve standards.
DIN - Deutsches Institut für Normung - valve related standards:
  • DIN 475-1
    Widths across flats for bolts, screws, valves and fittings
  • DIN 475-2
    Wrench and socket openings
  • DIN 477-1
    Gas cylinder valves rated for test pressures up to 300 bar; types, sizes and outlets
  • DIN 477-4
    Compressed gas cylinder valves; swing check valves for camping-cylinders
  • DIN 477-5
    Gas cylinder valves - Part 5: For test pressure up to 450 bar max.; Outlet connections
  • DIN 477-6
    Gas cylinder valves; test pressures 300 bar and 450 bar, with cylindrical thread for valve stem and gas cylinder neck for breathing apparatus; sizes, threads
  • DIN 477-9 (Draft standard)
    Gas cylinder valves, for highest grade gases; sizes, connections, threads
  • DIN 1690-10
    Technical delivery conditions for castings of metallic materials; supplementary requirements for steel castings used for heavy-duty valves
  • DIN 3202-4
    Face-to-face and center-to-face dimensions of valves; Valves with female thread connection
  • DIN 3202-5
    Face-to-face and center-to-face dimensions of valves; valves for connection with compression couplings
  • DIN 3230-3
    Technical delivery conditions for valves; Compilation of test methods
  • DIN 3230-4
    Technical Conditions of Delivery for Valves; Valves for Potable Water Service, Requirements and Testing
  • DIN 3230-5
    Technical delivery conditions; valves for gas installations and gas pipelines; requirements and testing
  • DIN 3230-6
    Technical delivery conditions for valves; requirements and methods of test for valves for use with flammable liquids
  • DIN 3266-1
    Valves for drinking water installations on private premises; PN 10 pipe interrupters, pipe disconnectors, anti-vacuum valves
  • DIN 3266-2
    Valves for drinking water installations on private premises; PN 10 pipe interrupters, pipe disconnectors, anti-vacuum valves; testing
  • DIN 3320-1
    Safety valves; safety shut-off valves; definitions, sizing, marking
  • DIN 3320-3 (Draft standard)
    Safety valves; safety shut-off valves; center for face dimensions of flanged safety valves to PN 40 and to DN 250 inlet
  • DIN 3339
    Valves; body component materials
  • DIN 3352-1
    Gate Valves; General Information
  • DIN 3352-2
    Cast iron gate valves, with metallic seat and inside screw stem
  • DIN 3352-3
    Cast iron gate valves, with metallic seat and outside screw stem
  • DIN 3352-4
    Cast iron gate valves with elastomeric obturator seatings and inside screw stem
  • DIN 3352-5
    Steel gate valves, isomorphs series
  • DIN 3352-13
    Double-socket cast iron gate valves, with elastomeric obturator seat and inside screw stem
  • DIN 3356-1
    Globe valves; General data
  • DIN 3356-2
    Globe valves; Cast iron stop valves
  • DIN 3356-3
    Globe valves; Unalloyed steel stop valves
  • DIN 3356-4
    Globe valves; High temperature steel stop valves
  • DIN 3356-5
    Globe valves; Stainless steel stop valves
  • DIN 3357-1
    Metal ball valves; general requirements and methods of test
  • DIN 3357-2
    Full bore steel ball valves
  • DIN 3357-3
    Reduced bore steel ball valves
  • DIN 3357-4
    Full bore nonferrous metal ball valves
  • DIN 3357-5
    Reduced bore nonferrous metal ball valves
  • DIN 3381
    Safety devices for gas supply installations operating at working pressures up to 100 bar; pressure relief governors and safety shut-off devices
  • DIN 3399
    Gas low-pressure cut-off valves; safety requirements, testing
  • DIN 3441-1
    Unplasticized polyvinyl chloride (PVC-U) valves; requirements and testing
  • DIN 3441-2
    Unplasticized polyvinyl chloride (PVC-U) valves; ball valves; dimensions
  • DIN 3441-3
    Unplasticized polyvinyl chloride (PVC-U) valves; diaphragm valves; dimensions
  • DIN 3441-4
    Valves of Rigid PVC (Unplasticized or Rigid Polyvinyl Chloride); Y-valves (Inclined-seat Valves), Dimensions
  • DIN 3441-5
    Unplasticized polyvinyl chloride (PVC-U) valves; PN 6 and PN 10 wafer type butterfly valves; dimensions
  • DIN 3441-6
    Unplasticized polyvinyl chloride (UPVC) valves; gate valves with inside screw stem; dimensions
  • DIN 3442-1
    Polypropylene (PP) valves; requirements and testing
  • DIN 3442-2
    Fittings of PP (Polypropylene); Ball valves, Dimensions
  • DIN 3442-3
    Polypropylene (PP) valves; diaphragm valves; dimensions
  • DIN 3475
    Spheroidal graphite cast iron valves and fittings provided with internal corrosion protection by means of enamelling, for use in drinking water supply systems; requirements and testing
  • DIN 3476
    Corrosion protection of water valves and pipe fittings by epoxy powder or liquid epoxy resin linings - Requirements and testing
  • DIN 3500
    PN 10 piston type gate valves for use in drinking water supply systems
  • DIN 3502
    Stopvalves for drinking water supplies on and in private property; straight pattern globe valves with oblique bonnet, rated for nominal pressure PN 10
  • DIN 3512
    Stopvalves for domestic water supply - Two-way valves - Vertical bonnet type PN 10; Straight pattern globe valve; Technical rule of the DVGW
  • DIN 3535-1
    Sealants for gas supplies; elastomeric gasket materials for gas valves in domestic installations; requirements and tests
  • DIN 3535-5
    Rubber/cork and rubber/cork synthetic fiber based gasket materials for use with gas valves, gas appliances and gas pipe work
  • DIN 3535-6
    Gaskets for gas supply - Part 6: Gasket materials based on synthetic fibers, graphite or polytetrafluoroethylen (PTFE) for gas valves, gas appliances and gas mains
  • DIN 3537-1
    Gas stop valves rated for pressures up to 4 bar; requirements and acceptance testing
  • DIN 3543-1
    Metal tapping valves; requirements, testing
  • DIN 3543-2
    Metallic tapping stop valves; dimensions
  • DIN 3543-3, Publication date:1978-07
    PVC tapping valves for plastic pipes; dimensions
  • DIN 3543-4
    High density polyethylene (HDPE) tapping valves for HDPE pipes; dimensions
  • DIN 3544-1
    High-density polyethylene (HDPE) valves; tapping valves; requirements and test
  • DIN 3852-1
    Ports and stud ends with metric fine pitch thread, for use with compression couplings, valves and screw plugs; Dimensions
  • DIN 3852-2
    Stud ends and tapped holes with pipe thread, for use with compression couplings, valves and screw plugs; Dimensions
  • DIN 3852-11
    Stud ends and tapped holes for use with compression couplings, valves and screw plugs - Type E stud end dimensions
  • DIN 19208
    Flow measurement; mating dimensions and application of shut-off valves for differential pressure transducers and differential pressure piping
  • DIN 19578-1
    Stop valves for site drainage systems; anti-flooding valves for faucal sewage systems; requirements
  • DIN 20042
    Water valve, nominal pressure 40 - Dimensions and requirements
  • DIN EN 28233
    Thermoplastics valves; torques; test method (ISO 8233:1988)
  • DIN 30677-1
    Corrosion protection of buried valves; coating for normal requirement
  • DIN 30677-2
    External corrosion protection of buried valves; heavy-duty thermoset plastics coatings
  • DIN 32509
    Hand-operated shut-off valves for welding, cutting and allied processes - Type of construction, safety requirements, tests
  • DIN 42560
    Transformers; Throttle-valves NW 80, Dimensions, Tightness Testing
  • DIN 74279
    Air braking systems - Charging valves
  • DIN 86251
    Shut off valves for shipboard use, of cast iron, with flanges, DN 15 to 500
  • DIN 86252
    Non return valves for shipboard use, cut off type, of cast iron, with flanges, DN 15 to 500
  • DIN 86260
    Shut off valves for shipboard use, of gun metal, with flanges, DN 15 to 500
  • DIN 86261
    Non return valves for shipboard use, cut off type, of gun metal, with flanges, DN 15 to 500
  • DIN 86501
    Valves, screwed bonnet type of gun metal with 24�-connection with port end W according to DIN 3861
  • DIN 86528
    Tab washers for screwed bonnet valves
  • DIN 86552
    Valves, screwed bonnet type of steel with 24�-connection with port end W according to DIN 3861
  • DIN 86720
    Gate valves flat sided of gun metal with screwed bonnet and flanges, DN 20 to DN 100, PN 16
  • DIN 87101, Publication date:2003-10
    Non-return flaps (storm valves), self-closing, vertical type, DN 50 up to DN 150, PN 1 - Mating dimensions for flanges according to PN 10
  • DIN 87901
    Sniffle valves for pumps
  • DIN EN 488
    District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Steel valve assembly for steel service pipes, polyurethane thermal insulation and outer casing of polyethylene; German version EN 488:2003
  • DIN EN 558-1
    Face-to-face and center-to-face dimensions of metal industrial valves for use in flanged pipe systems - PN designated valves
  • DIN EN 558-2
    Face-to-face and center-to-face dimensions of metal industrial valves for use in flanged pipe systems - Class-designated valves
  • DIN EN 736-1
    Valves - Terminology - Types of valves
  • DIN EN 736-2
    Valves - Terminology - Part 2: Definition of components of valves
  • DIN EN 736-3
    Valves - Terminology - Part 3: Definition of terms (includes Amendment A1:2001); English version of DIN EN 736-3:1999 + A1:2001
  • DIN EN 917
    Plastics piping systems - Thermoplastics valves - Test methods for resistance to internal pressure and leak-tightness
  • DIN EN 1092-1
    Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories - Part 1: Steel flanges, PN designated
  • DIN EN 1092-2
    Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 2: Cast iron flanges
  • DIN EN 1092-4
    Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Part 4: Aluminium alloy flanges
  • DIN EN 1680
    Plastics piping systems - Valves for polyethylene (PE) piping systems - Test method for leaktightness under and after bending applied to the operating mechanism
  • DIN EN 1705
    Plastics piping systems - Thermoplastics valves - Test method for the integrity of a valve after an external blow; German version EN 1705:1996
  • DIN EN 28233
