DIN - Pipe, Tube and Fittings Standards and Specifications
Deutsches Institut für Normung - DIN - pipe, tube and fittings standards and specifications.
Industrial pipe, tube and fittings standards and specifications from the DIN - Deutsches Institut für Normung:
  • DIN 76-2:1984
    Thread run-outs and thread undercuts for pipe threads conforming to ISO 228 part 1
  • DIN EN 259-1:2001
    Wall coverings in roll form - Heavy duty wallcoverings - Part 1: Specifications;
  • DIN EN 259-2:2001
    Wall coverings in roll form - Heavy duty wallcoverings - Part 2: Determination of impact resistance;
  • DIN 431:2000
    Pipe nuts with thread according to DIN ISO 228-1
  • DIN 906:1992
    Hexagon socket pipe plugs
  • DIN 909:1992
    Hexagon head pipe plugs
  • DIN 1230-P1:1992
    Vitrified clay for sewerage; special fittings and adapters with flexible mechanical joint and compatible accessories; dimensions
  • DIN 1389:2001
    WC connectors - Requirements and testing
  • DIN 1478:1975
    Turnbuckles Made from Steel Tube or Round Steel Bar
  • DIN 1986-4:2003
    Drainage systems on private ground - Part 4: Fields of application of sewage pipes and fittings of different materials
  • DIN 1988-3 Beiblatt 1:1988
    Codes of practice for drinking water installations (TRWI); examples for calculation; DVGW code of practice
  • DIN 2406:1968
    Pipelines symbols - pipe classes
  • DIN 2559-2:1984
    Edge preparation for welding; matching of inside diameter for circumferential welds on seamless pipes
  • DIN 2559-3:1990
    Preparation of welds; matching of inside diameters for circumferential welds on welded pipes
  • DIN 2559-4:1994
    Preparation of welds; part 4: matching of inside diameters for circumferential welds on seamless pipes of stainless steels
  • DIN 2609:1991
    Steel butt-welding pipe fittings; technical delivery conditions
  • DIN 2614:1990
    Cement mortar linings for ductile iron and steel pipes and fittings; application, requirements and testing
  • DIN 2615-1:1992
    Steel butt-welding pipes fittings; tees with reduced pressure factor
  • DIN 2615-2:1992
    Steel butt-welding pipe fittings; tees for use at full service pressure
  • DIN 2616-1:1991
    Steel butt-welding pipe fittings; eccentric reducers with reduced pressure factor
  • DIN 2616-2:1991
    Steel butt-welding pipe fittings; reducers for use at full service pressure
  • DIN 2617:1991
    Steel butt-welding pipe fittings; caps
  • DIN 2618:1968
    Butt welding steel fittings; welding saddles, nominal pressure
  • DIN 2619:1968
    Butt welding steel fitting; bends for welding, nominal pressure 16
  • DIN 2826:1994
    Hose fittings with clamp unit for steam and hot water, DN 15 up to DN 50, up to 18 bar
  • DIN 2848:2002
    Flanged steel pipes and flanged steel or cast iron fittings with lining - PN 10, PN 25 and PN 40
  • DIN 2856:1986
    Capillary solder fittings; assembly dimensions and testing
  • DIN 2873:2002
    Flanged fitting pipes and flanged steel glass lined - PN 10 and PN 25
  • DIN 2874:2002
    Steel flanged pipes and steel and cast iron flanged fittings lined with PTFE or PFA - Technical specifications
  • DIN 2875:2002
    Flanged steel pipes and flanged steel fittings with hard or soft rubber lining - Technical specifications
  • DIN 2876:2002
    Flanged steel pipes and flanged steel fittings glass lined - Technical specifications
  • DIN 2950:1983
    Malleable cast iron fittings
  • DIN 2980:1977
    Screwed steel pipe fittings
  • DIN 2981:1982
    Threaded steel pipe fitting; fittings with long screw thread
  • DIN 2982:1977
    Screwed steel pipe fitting; parallel nipples, taper nipples
  • DIN 2983:1977
    Screwed steel pipe fittings, bends
  • DIN 2986:1977
    Threaded steel pipe fittings; sockets
  • DIN 2987-P1:1977
    Threaded steel pipe fittings crosses, tees, elbows
  • DIN 2987-P2:1977
    Threaded steel pipe fittings reducing tees and elbows
  • DIN 2988:1977
    Reducing sockets; threaded steel pipe fittings
  • DIN 2990:1977
    Threaded steel pipe fitting; hexagon nipple; bushings
  • DIN 2991:1977
    Threaded steel pipe sitting; plugs, caps
  • DIN 2993:1977
    Threaded steel pipe fittings; pipe unions
  • DIN 2999-2:1973
    Whitworth Pipe Threads for Tubes and Fittings; Cylindrical Internal Thread and Conical External Thread, Gauging System and Use of Gauges
  • DIN 2999-3:1973
    Whitworth Pipe Threads for Tubes and Fittings; Gauge Dimensions
  • DIN 2999-4:1986
    Pipe threads for tubes and fittings; sizes for taper screw limit plug gauges for parallel internal thread
  • DIN 2999-5:1973
    Whitworth Pipe Threads for Tubes and Fittings; Cylindrical Screw Limit Ring Gauges for Gauging Conical External Threads, Sizes
  • DIN 2999-6:1975
    Whitworth Pipe Threads for Tubes and Fittings; Conical Screw Check Plugs, Sizes
  • DIN 3567:1963
    Pipe Brackets for NW 20 to 500
  • DIN 3568:1977
    Clamping plates for the suspension of pipes on I and IP steel beams
  • DIN 3570:1968
    Steel Strap for Tubes of NW 20 to 500
  • DIN 3575:1962
    Hanger straps with welding end for pipe hanging
  • DIN 3853:2001
    Non-soldering and soldering compression fittings - Stud ends for use with union nut; Design sheet
  • DIN 3858:1988
    Whitworth pipe threads for pipe couplings; parallel internal threads and taper external threads; thread dimensions
  • DIN 3861:2002
    Non-soldering compression fittings - Compression rings - Design
  • DIN 3867:2003
    Non-soldering compression couplings - Pressure bush for butt joints
  • DIN 3870:2001
    Non-soldering and soldering compression fittings - Union nuts series LL
  • DIN 3871:1995
    Non-soldering and soldering compression couplings - Socket unions
  • DIN 3872:2003
    Non-soldering compression couplings - Union nuts for butt joints
  • DIN 3904:1987
    Olive type compression couplings; male stud elbows
  • DIN 3907:1987
    Olive type compression couplings; male stud tees (stud branch)
  • DIN 3908:1984
    Solderless compression couplings with olive equal
  • DIN 3911:1984
    Solderless compression couplings with olive elbow
  • DIN 3914:1987
    Olive type compression couplings; male stud tees (stud run)
  • DIN 3942:2002
    Non-soldered compression fittings - Swivel elbows with 24ü cone connectors with O-ring - Adjustable, for design and type of compression end according to DIN EN ISO 8434-1
  • DIN 3943:2002
    Non-soldered compression fittings - Swivel branch tees with 24ü cone connectors with O-ring - Adjustable, for design and type of compression end according to DIN EN ISO 8434-1
  • DIN 3944:2002
    Non-soldered compression fittings - L-adaptors with 24ü cone connectors and O-ring - Adjustable, for design and type of compression end according to DIN EN ISO 8434-1
  • DIN 3945:2002
    Non-soldered compression fittings - Straight stud swivel adaptor with 24ü cone connectors with O-ring - For design and type of compression end according to DIN EN ISO 8434-1
  • DIN 3952:1984
    Solderless compression couplings with olive male, stud elbow assemblies
  • DIN 3953:1984
    Solderless compression couplings with olive male, stud tee ( stud branch) assemblies
  • DIN 3954:1984
    Solderless compression couplings with olive male, stud tee (stud run) assemblies
  • DIN 4032:1981
    Concrete pipes and fitting; dimensions, technical conditions of delivery
  • DIN 4060:1998
    Joints of sewer and drain pipes with elastomeric seals - Requirements and testing on joints with elastomeric seals
  • DIN 4922-2:1981
    Steel Filter Pipes for Drilled Wells with Screwed Connection DN 100 to DN 500
  • DIN 4941:1965
    Screw threads for drill pipes for seamless drill pipes for water and rock drillings according to the percussion drilling and core drilling method
  • DIN 7340:1993
    Tubular rivets cut from the tube
  • DIN 7591:1981
    Water fittings for domestic installation; Screwed unions with flat gasket for hose connection on either side, designed for nominal pressure 10
  • DIN 7593:1981
    Water fittings for domestic installation; Screwed unions with gasket for connection to copper tube on either side, designed for nominal pressure 10
  • DIN 7632:1985
    Compression couplings with spherical liner; reducers
  • DIN 7639:1985
    Compression couplings with spherical liner; equal tees
  • DIN 8063-1:1986
    Pipe joint assemblies and fittings for unplasticized polyvinyl chloride (U-PVC) pressure pipelines; dimensions of socket bends
  • DIN 8063-2:1980
    Pipe Joints and Pipe Fittings for Pipes under Pressure made of Unplasticized Polyvinyl Chloride (Rigid PVC); Bends Made by Injection Moulding for Bonding; Dimensions
  • DIN 8063-3:2002
    Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 3: Unions; Dimensions
  • DIN 8063-4:1983
    Pipe joint assemblies and fittings for unplasticized polyvinyl chloride (PVC-U) pressure pipes; bushings, flanges, seals; dimensions
  • DIN 8063-5:1999
    Pipe joints components of unplasticized poly(vinyl chloride) (PVC-U) for pipes under pressure - Part 5: General quality requirements, testing
  • DIN 8063-6:2002
    Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 6: Injection-moulded elbows for solvent cementing; Dimensions
  • DIN 8063-7:1980
    Pipe joints and their elements of unplasticized polyvinylchloride (unplasticized PVC) under pressure; tees and branches of injection moulded for cold welding, dimensions
  • DIN 8063-8:2002
    Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 8: Injection-moulded sockets, caps and nipples for solvent cementing; Dimensions
  • DIN 8063-9:1980
    Pipe joints and their elements for pipes of unplasticized polyvinylchloride (unplasticized PVC) under pressure; sockets reducing of injection moulded for cold welding, dimensions
  • DIN 8063-10:2002
    Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 10: Wall bracket elbows; Dimensions
  • DIN 8063-11:1980
    Pipe Joints and Pipe Fittings for Pipes under Pressure made of Unplasticized Polyvinyl Chloride (Rigid PVC); Sockets with Primary Element of Copper-Zinc-Alloy (Brass) for Bonding; Dimensions
  • DIN 8063-12:1987
    Pipe joint assemblies and fittings of unplasticized polyvinyl chloride (U-PVC) pressure pipelines; dimensions of flanged and socket fittings
  • DIN 8975-P9:1983
    Refrigeration plants; safety principles for design, equipment and installation, flexible pipe elements in the refrigerant circuit
  • DIN 8076-1:1984
    Thermoplastics pressure pipelines; metal compression fittings for polyethylene (PE) pipes; general quality requirements; testing
  • DIN 8076-3:1994
    Pressure pipelines made from thermoplastics materials - Part 3: Plastic joints for PE pipes; general quality requirements, testing
  • DIN 8906:1990
    PN 40 flared flange solderless compression couplings for use in refrigerating systems
  • DIN 8912:1990
    Coupling nuts and screwed plugs for use with PN 40 flared flange solderless compression couplings in refrigerating systems
  • DIN 8914:1990
    90ü tapered seal rings and caps for use with PN 40 flared flange solderless compression couplings in refrigerating systems
  • DIN 16450:1994
    Socket-fittings for pressure piping of unplasticized polyvinylchloride (PVC-U); symbols
  • DIN 16451-P1:1994
    Ductile iron (GGG) fittings for use with unplasticized polyvinyl chloride (PVC-U) pressure pipes - technical delivery conditions
  • DIN 16867:1982
    Glass fibre reinforced polyester resin (UP-GF) pipes, fittings and joints for use in chemical pipelines; Technical delivery conditions
  • DIN 16961-1:2000
    Pipes and fittings of thermoplastic materials with profiled wall and smooth pipe inside - Part 1: Dimensions
  • DIN 16961-2:2000
    Pipes and fittings of thermoplastics materials with profiled wall and smooth pipe inside - Part 2: Technical delivery specifications
  • DIN 16967-2:1982
    Glass fibre reinforced epoxy resin (EP-GF) pipe fittings and joints; Elbows, Tees, Dimensions
  • DIN 16928:1979
    Pipes of Thermoplastic Materials; Pipe Joints, Elements for Pipes, Laying; General Directions
  • DIN 16962-1:1980
    Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Bends of Segmental Construction for Butt-welding, Dimensions
  • DIN 16962-2:1983
    Pipe joint assemblies and fittings for types 1 and 2 polypropylene (PP) pressure pipes; tees and branches produced by segment inserts and necking for butt welding; dimensions
  • DIN 16962-3:1980
    Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Bends Formed from Pipe for Butt-welding, Dimensions
  • DIN 16962-4:1988
    Pipe joint assemblies and fittings for types 1 and 2 polypropylene (PP) pressure pipes; adaptors for fusion jointing, flanges and sealing elements; dimensions
  • DIN 16962-5:2000
    Pipe joints and components of polypropylene (PP) for pipes under pressure, PP-H 100, PP-B 80 and PP-R 80 - Part 5: General quality requirements, testing
  • DIN 16962-6:1980
    Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Injection Moulded Elbows for Socket-welding, Dimensions
  • DIN 16962-7:1980
    Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Injection Moulded Tee Pieces for Socket-welding, Dimensions
  • DIN 16962-8:1980
    Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Injection Moulded Sockets and Caps for Socket-welding, Dimensions
  • DIN 16962-9:1983
    Pipe joint assemblies and fittings for types 1 and 2 polypropylene (PP) pressure pipes; injection moulded reducers and nipples for socket welding; dimensions
  • DIN 16962-10:1989
    Pipe joint assemblies and fittings for types 1 to 3 polypropylene (PP) pressure pipes; injection-moulded fittings for butt welding; dimensions
  • DIN 16962-11:1980
    Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Turned and Pressed Reducing Sockets for Butt-welding,
  • DIN 16962-12:1999
    Pipe joints and components of polypropylene (PP) for pipes under pressure, PP-H 100, PP-B 80 and PP-R 80 - Part 12: Flange adapters, flanges, sealing rings for socket welding; dimensions
  • DIN 16962-13:1987
    Pipe joint assemblies and fittings for type 1 and type 2 polypropylene (PP) pressure pipes; pipe couplings; dimensions
  • DIN 16963-1:1980
    Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Pipe Bends of Segmental Construction for Butt-welding, Dimensions
  • DIN 16963-2:1983
    Pipe joint assemblies and fittings for types 1 and 2 high-density polyethylene (HDPE) pressure pipes; tees and branches produced by segment inserts and necking for butt welding; dimensions
  • DIN 16963-3:1980
    Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Pipe Bends for Butt-welding, Dimensions
  • DIN 16963-4:1988
    Pipe joint assemblies and fittings for high-density polyethylene (PE-HD) pressure pipes; adaptors for fusion jointing, flanges and sealing elements; dimensions
  • DIN 16963-5:1999
    Pipe joints and components of polyethylene (PE) for pipes under pressure, PE 80 and PE 100 - Part 5: General quality requirements, testing
  • DIN 16963-6:1989
    Pipe joint assemblies and fittings for high-density polyethylene (PE-HD) pressure pipes; injection-moulded fittings for butt welding; dimensions
  • DIN 16963-7:1989
    Pipe joint assemblies and fittings for high-density polyethylene (PE-HD) pressure pipes; fittings for resistance welding; dimensions
  • DIN 16963-8:1980
    Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Injection Moulded Elbows for Socket-welding, Dimensions
  • DIN 16963-9:1980
    Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Injection Moulded Tee Pieces for Socket-welding, Dimensions
  • DIN 16963-10:1980
    Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Injection Moulded Sockets and Caps for Socket-welding, Dimensions
  • DIN 16963-11:1999
    Pipe joints and components of polyethylene (PE) for pipes under pressure, PE 80 and PE 100 - Part 11: Flange adapters, flanges, sealing rings for socket welding; dimensions
  • DIN 16963-13:1980
    Pipe Joints and Elements for High Pressure Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Turned and Pressed Reducing Sockets for Butt-welding, Dimensions
  • DIN 16963-14:1983
    Pipe joint assemblies and fittings for types 1 and 2 high-density polyethylene (HDPE) pressure pipes; injection moulded reducers and nipples for socket welding; dimensions
  • DIN 16963-15:1987
    Pipe joint assemblies and fittings for high-density polyethylene (HDPE) pressure pipes; pipe couplings; dimensions
  • DIN 16966-1:1988
    Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joint assemblies; fittings; general quality requirements and testing
  • DIN 16966-2:1982
    Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joints; Elbows, Dimensions
  • DIN 16966-4:1982
    Glass fibre reinforced polyester resin (UP-GF) pipe fittings an joints; Tees, Nozzles, Dimensions
  • DIN 16966-5:1982
    Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joints; Reducers, Dimensions
  • DIN 16966-6:1982
    Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joint assemblies; collars, flanges, joint rings, dimensions
  • DIN 16966-7:1995
    Pipe joints and their elements of glass fibre reinforced polyester resins - Part 7: Bushings, flanges, flanged and butt joints; general quality requirements and test methods
  • DIN 16966-8:1982
    Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joints; Laminated joints; Dimensions
  • DIN 16970:1970
    Adhesives for Bonding Pipes and Pipe System Elements of Rigid PVC; General Quality Requirements and Testings
  • DIN 19522:2000
    Cast iron drainage pipes and fittings without sockets (SML)
  • DIN 19530-P1:1983
    Steel socket pipes and fittings for sewers; dimensions
  • DIN 19530-P2:1983
    Steel socket pipes and fittings for sewers; technical delivery conditions
  • DIN 19531-10:1999
    Pipes and fittings made of unplasticized polyvinyl chloride (PVC-U) socket for waste and soil discharge systems inside buildings - Part 10: Fire behaviour, quality control and installation recommendations
  • DIN 19532:1979
    Pipelines of unplasticized plyvinyl chloride (rigid PVS, PVC-U) for drinking water supply; pipes, pipe joints, pipeline parts
  • DIN 19535-10:2000
    High-density polyethylene (PE-HD) pipes and fittings for hot-water resistant waste and soil discharge systems (HT) inside buildings - Part 10: Fire behaviour, quality control and installation recommendations
  • DIN 19537-1:1983
    High density polyethylene (HDPE) pipes and fittings for drains and sewers; dimensions
  • DIN 19537-2:1988
    High-density polyethylene (HDPE) pipes and fittings for drains and sewers; technical delivery conditions
  • DIN 19538-10:1999
    Pipes and fittings made of chlorinated polyvinyl chloride (PVC-C) for hot-water resistant waste and soil discharge systems inside buildings - Part 10: Fire behaviour, quality control and installation recommendations
  • DIN 19559-1:1983
    Measurement of flow of waste water in open channels and gravity conduits; general information
  • DIN 19565-1:1989
    Centrifugally cast and filled polyester resin glass fibre reinforced (UP-GF) pipes and fittings for buried drains and sewers; dimensions and technical delivery conditions
  • DIN 19800-P1:1973
    Asbestos cement pipes and fittings for pressure pipelines; pipes, dimensions
  • DIN 19850-1:1996
    Fibre cement pipes and fittings for sewers - Part 1: Dimensions of pipes, branches and bends
  • DIN 19850-2:1996
    Fibre cement pipes and fittings for sewers - Part 2: Dimensions of joints
  • DIN 24147 P1:1998
    Fittings for use in air distribution systems; overview and dimensions
  • DIN 28065:1993
    Glass lined apparatus and pipe equipment; thermal shock resistance
  • DIN 28187:1991
    Tubular heat exchangers; connections tube to tube sheet
  • DIN 28600:1983
    Ductile iron pressure pipes & fittings for Gas and Water pipelines
  • DIN 28603:2002
    Ductile iron pipes and fittings - Push-in joints - Survey, sockets and gaskets
  • DIN 28624:1990
    Ductile iron collars for use with gas and water pipes dimensions and mass
  • DIN 28631:1996
    Ductile iron castings for gas and water pressure pipelines; MI-fittings, socketed spigots with plane end branch; application dimensions and masses
  • DIN 28633:1996
    Ductile iron castings for gas and water pressure pipelines; IT-fitting; all plane end tees; application, dimensions and masses
  • DIN 28645:1990
    Ductile iron double-flanged tapers for use with gas and water pipes dimensions and mass
  • DIN 30670:1991
    Polyethylen coatings of steel pipes and fittings - Requirements and testing
  • DIN 52613:1977
    Thermal Insulation Testings; Determination of Thermal Conductivity by the Tube Method
  • DIN 53769-1:1988
    Testing of glass fibre reinforced plastics pipes; determination of the longitudinal shear strength of type B pipe fittings
  • DIN 53769-2:1986
    Testing of glass fibre reinforced plastics pipes; long-term hydrostatic pressure test
  • DIN 53769-3:1988
    Testing of glass fibre reinforced plastics pipes; determination of initial and long-term ring stiffness
  • DIN 53769-6:1989
    Testing of glass fibre reinforced plastics pipes; Testing of pipes and fittings under pulsating internal pressure
  • DIN 86041-1:1996
    Welding Flanges - Part 1: Tanks and sea boxes, nominal pressure 10 and 16
  • DIN 86041-2:1996
    Welding flanges - Part 2: Outboard connections, nominal pressure 10, 16, 40
  • DIN 86086:1996
    Fittings for butt welding into copper-nickel-alloy pipelines - Technical specifications
  • DIN 86288:1989
    Pipework on ships and marine structures; socketed steel pipes and fittings; fittings for use in shipbuilding
  • DIN EN 253:2003
    District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Pipe assembly of steel service pipe, polyurethane thermal insulation and outer casing of polyethylene;
  • DIN EN 295-1:1999
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 1: Requirements
  • DIN EN 295-2:1999
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 2: Quality control and sampling
  • DIN EN 295-3:1999
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 3: Test methods
  • DIN EN 295-4:1995
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 4: Requirements for special fittings, adapters and compatible accessories
  • DIN EN 295-5:1999
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 5: Requirements for perforated vitrified clay pipes and fittings
  • DIN EN 295-6:1995
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 6: Requirements for vitrified clay manholes
  • DIN EN 295-7:1995
    Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 7: Requirements for vitrified clay pipes and joints for pipe jacking
  • DIN EN 448:2003
    District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Fitting assemblies of steel service pipes, polyurethane thermal insulation and outer casing of polyethylene
  • DIN EN 476:1997
    General requirements for components used in discharge pipes, drains and sewers for gravity systems;
  • DIN EN 489:2003
    District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Joint assembly for steel service pipes, polyurethane thermal insulation and outer casing of polyethylene;
  • DIN EN 545:2002
    Ductile iron pipes, fittings, accessories and their joints for water pipelines - Requirements and test methods;
  • DIN EN 578:1993
    Plastics piping systems; plastics pipes and fittings; determination of the opacity
  • DIN EN 588-1:1996
    Fibre-cement pipes for sewers and drains - Part 1: Pipes, joints and fittings for gravity systems;
  • DIN EN 588-2:2002
    Fibre cement pipes for drains and sewers - Part 2: Manholes and inspection chambers
  • DIN EN 598:1994
    Ductile iron pipes, fittings, accessories and their joints for sewerage application - Requirements and test methods
  • DIN EN 607:2004
    Eaves gutters and fittings made of PVC-U - Definitions, requirements and testing;
  • DIN EN 639:1994
    Common requirements for concrete pressure pipes, including joints and fittings;
  • DIN EN 640:1994
    Reinforced concrete pressure pipes and distributed reinforcement concrete pressure pipes (non-cylinder type), including joints and fittings
  • DIN EN 641:1994
    Reinforced concrete pressure pipes, cylinder type, including joints and fittings
  • DIN EN 642:1994
    Prestressed concrete pressure pipes, cylinder and non-cylinder, including joints, fittings and specific requirement for prestressing steel for pipes
  • DIN EN 681-1:2003
    Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber;
  • DIN EN 705:1994
    Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analyses and their use
  • DIN EN 713:1994
    Plastics piping systems; mechanical joints between fittings and polyolefin pressure pipes; test method for leaktightness under internal pressure of assemblies subjected to bending
  • DIN EN 714:1994
    Thermoplastics piping systems - Non-end-load-bearing elastomeric sealing ring type joints between pressure pipes and moulded fittings - Test method for leaktightness under internal hydrostatic pressure whithout end thrust
  • DIN EN 715:1994
    Thermoplastics piping systems; end-load bearing joints between small diameter pressure pipes and fittings; test method for leaktightness under internal water pressure, including end thrust
  • DIN EN 723:1996
    Copper and copper alloys - Combustion method for determination of carbon on the inner surface of copper tubes or fittings;
  • DIN EN 727:1995
    Plastics piping and ducting systems - Thermoplastics pipes and fittings - Determination of Vicat softening temperature (VST);
  • DIN EN 728:1997
    Plastics piping and ducting systems - Polyolefin pipes and fittings - Determination of oxidation induction time
  • DIN EN 754-1:1997
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 1: Technical conditions for inspection and delivery;
  • DIN EN 754-2:1997
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 2: Mechanical properties;
  • DIN EN 754-3:1996
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 3: Round bars, tolerances on dimensions and form;
  • DIN EN 754-4:1996
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 4: Square bars, tolerances on dimensions and form;
  • DIN EN 754-5:1996
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 5: Rectangular bars, tolerances on dimensions and form;
  • DIN EN 754-6:1996
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 6: Hexagonal bars; tolerances on dimensions and form;
  • DIN EN 754-7:1998
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 7: Seamless tubes, tolerances on dimensions and form;
  • DIN EN 754-8:1998
    Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 8: Porthole tubes, tolerances on dimensions and form;
  • DIN EN 755-1:1997
    Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 1: Technical conditions for inspection and delivery
  • DIN EN 755-2:1997
    Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 2: Mechanical properties;
  • DIN EN 755-3:1995
    Aluminium and aluminium alloys - Extruded rod/bar, tube and profile - Part 3: Round bars; tolerances on dimensions and form;
  • DIN EN 755-4:1995
    Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 4: Square bars, tolerances on dimensions and form;
  • DIN EN 755-5:1995
    Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 5: Rectangular bars, tolerances on dimensions and form;
  • DIN EN 755-6:1995
    Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 6: Hexagonal bars, tolerances on dimensions and form;
  • DIN EN 763:1994
    Plastics piping and ducting systems - Injection-moulded thermoplastics fittings - Test method for visually assessing effects of heating;
  • DIN EN 802:1994
    Plastics piping and ducting systems - Injection-moulded thermoplastics fittings for pressure piping systems - Test method for maximum deformation by crushing;
  • DIN EN 803:1994
    Plastics piping systems - Injection-moulded thermoplastics fittings for elastic sealing ring type joints for pressure piping - Test method for resistance to a short-term internal pressure without end thrust
  • DIN EN 804:1994
    Plastics piping systems - Injection-moulded socket fittings for solvent-cemented joints for pressure piping - Test method for resistance to a short-term internal hydrostatic pressure;
  • DIN EN 911:1995
    Plastics piping systems - Elastomeric sealing ring type joints and mechanical joints for thermoplastics pressure piping - Test method for leaktightness under external hydrostatic pressure;
  • DIN EN 922:1995
    Plastics piping and ducting systems - Pipes and fittings of unplasticized poly(vinyl chloride) (PVC-U) - Specimen preparation for determination of the viscosity number and calculation of the K-value;
  • DIN EN 969:1995
    Ductile iron pipes, fittings, accessories and their joints for gas pipelines - Requirements and test methods;
  • DIN EN 1119:1996
    Plastics piping systems - Joints for glass-reinforced thermosetting plastics (GRP) pipes and fittings - Test methods for leaktightness and resistance to damage of flexible and reduced articulation joints;
  • DIN EN 1120:1996
    Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Determination of the resistance to chemical attack from the inside of a section in a deflected condition;
  • DIN EN 1229:1996
    Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Test methods to prove the leaktightness of the wall under short-term internal pressure;
  • DIN EN 1277:2004
    Plastics piping systems - Thermoplastics piping systems for buried non-pressure applications - Test methods for leaktightness of elastomeric sealing ring type joints;
  • DIN EN 1716:1997
    Plastics piping systems - Polyethylene (PE) tapping tees - Test method for impact resistance of an asssembled tapping tee;
  • DIN EN 10233:1994
    Metallic materials; tube; flattening test
  • DIN EN 10234:1994
    Metallic materials; tube; drift expanding test
  • DIN EN 10242:1995
    Threaded pipe fittings in malleable cast iron;
