Proper allowance in the pipe line is important to eliminate undue stress from thermal expansion.
Z-Shaped Expansion Compensator
Minimum leg length of Z-shaped pressfit piping temperature expansion loops:
Z-Shaped temperature Expansion Compensator Diagram
U-Shaped Expansion Compensator
Minimum leg length of U-shaped pressfit piping temperature expansion loops:
  • 1 in (inch) = 25.4 mm = 0.0254 m = 0.08333 ft
  • Temperature Expansion
  • The Engineering ToolBox (2008). Pressfit Pipes - Expansion Loops. [online] Available at: https://www.engineeringtoolbox.com/pressfit-pipes-expansion-loops-d_1169.html [Accessed Day Month Year].
