Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
  • Isobaric specific heat (Cp ) is used for substances in a constant pressure (ΔP = 0) system.
  • I sochoric specific heat  (Cv ) is used for substances in a constant-volume , (= isovolumetric or isometric ) closed system.
The specific heat  - CP and CV - will vary with temperature. When calculating mass and volume flow of a substance in heated or cooled systems with high accuracy - the specific heat (= heat capacity) should be corrected according values in the table below.
Nitrogen accounts for 78 % of the atmospheric air volume. Nitrogen is an inert, neutral and colorless gas.
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K :
Nitrogen Gas - N2- Specific Heat vs. Temperature
Temperature
- T -
(K)
Specific Heat
- cp -
(kJ/(kg K))
175 1.039
200 1.039
225 1.039
250 1.039
275 1.039
300 1.040
325 1.040
350 1.041
375 1.042
400 1.044
450 1.049
500 1.056
550 1.065
600 1.075
650 1.086
700 1.098
750 1.110
800 1.122
850 1.134
900 1.146
950 1.157
1000 1.167
1050 1.177
1100 1.187
1150 1.196
1200 1.204
1250 1.212
1300 1.219
1350 1.226
1400 1.232
1500 1.244
1600 1.254
1700 1.263
1800 1.271
1900 1.278
2000 1.284
2100 1.290
2200 1.295
2300 1.300
2400 1.304
2500 1.307
2600 1.311
2700 1.314
2800 1.317
2900 1.320
3000 1.323
3500 1.333
4000 1.342
4500 1.349
5000 1.355
5500 1.362
6000 1.369
The values above apply to undissociated states. At high temperatures above 1500 K dissociation becomes appreciable and pressure is a significant variable.
See also other properties of Nitrogen at varying temperature and pressure : Density and specific weight , Dynamic and kinematic viscosity , Prandtl number , Specific heat (Heat capacity) , Thermal conductivity and thermal diffusivity , and thermophysical properties at standard conditions ,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature , Air - at Constant Temperature and Varying Pressure , Ammonia , Butane , Carbon dioxide , Carbon monoxide , Ethane , Ethanol , Ethylene , Hydrogen , Methane , Methanol , Oxygen , Propane and Water .
  • The Engineering ToolBox (2005). Nitrogen Gas - Specific Heat vs. Temperature. [online] Available at: https://www.engineeringtoolbox.com/nitrogen-d_977.html [Accessed Day Month Year].
