Ethane Gas - Specific Heat vs. Temperature
Specific heat of Ethane Gas - C2H6 - for temperatures ranging 250 - 900 K.
Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
  • Isobaric specific heat (Cp ) is used for substances in a constant pressure (ΔP = 0) system.
  • I sochoric specific heat  (Cv ) is used for substances in a constant-volume , (= isovolumetric or isometric ) closed system.
The specific heat  - CP and CV - will vary with temperature. When calculating mass and volume flow of a substance in heated or cooled systems with high accuracy - the specific heat (= heat capacity) should be corrected according values in the table below.
Specific heat of Ethane Gas - C2H6 - at temperatures ranging 250 - 900 K :
Ethane Gas - C2H6 - Specific Heat vs. Temperature
Temperature
- T -
(K)
Specific Heat
- cp -
(kJ/(kg K))
250 1.535
275 1.651
300 1.766
325 1.878
350 1.987
375 2.095
400 2.199
450 2.402
500 2.596
550 2.782
600 2.958
650 3.126
700 3.286
750 3.438
800 3.581
850 3.717
900 3.846
See also other properties of Ethane at varying temperature and pressure: Density and Specific Weight , Dynamic and Kinematic Viscosity and Thermal conductivity , and Thermophysical properties at standard conditions ,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature , Air - at Constant Temperature and Varying Pressure , Ammonia , Butane , Carbon dioxide , Carbon monoxide , Ethanol , Ethylene , Hydrogen , Methane , Methanol , Nitrogen , Oxygen , Propane and Water .
  • The Engineering ToolBox (2005). Ethane Gas - Specific Heat vs. Temperature. [online] Available at: https://www.engineeringtoolbox.com/ethane-d_982.html [Accessed Day Month Year].
