Cooling Tower Efficiency
Maximum cooling tower efficiency is limited by the cooling air wet-bulb temperature.
A cooling tower use evaporative cooling to reduce the temperature of circulated water, and
  • they can achieve water temperatures below the dry bulb temperature - tdb - of the cooling air
  • they are in general smaller and cheaper for the same cooling loads than other cooling systems
Cooling tower
Cooling towers are rated in terms of approach and range, where
  • the approach is the difference in temperature between the cooled water temperature and the entering air wet bulb temperature - twb - temperature
  • the range is the temperature difference between the water inlet and water exit
Note! - for a cooling tower based on evaporative cooling the maximum cooling tower efficiency is limited by the wet bulb temperature of the cooling air.
Cooling tower efficiency can be expressed as
μ = (ti - to) 100 / (ti -twb)                                  (1)
μ = cooling tower efficiency (%) - the common range is between 70 - 75%
ti = inlet temperature of water to the tower (oC, oF)
to = outlet temperature of water from the tower (oC, oF)
twb = wet bulb temperature of air (oC, oF)
The temperature difference between inlet and outlet water (ti - to) is normally in the range 10 - 15 oF.
The water consumption - or the amount of make up water - of a cooling tower is about 0.2-0.3 liter per minute and ton of refrigeration. Compared with the use and waste of city water the water consumption can be reduced with about 90 - 95%.
There are two main types of cooling towers
  • forced draught (using fans)
  • natural draught
Both types are based on evaporative cooling.
  • Natural draught cooling towers are more dependent on temperature gradients between air and water and the wind forces than forced draught cooling towers
  • The efficiency of natural draught towers are more variable over time and in general lower
Note! - be aware that a medium temperature system - like cooling a tower - are a known source of pathogenic bacteria causing the Legionnaires disease. Good cleaning and maintenance of the systems are important to minimize the risk.
  • Air Psychrometrics
  • The Engineering ToolBox (2004). Cooling Tower Efficiency. [online] Available at: https://www.engineeringtoolbox.com/cooling-tower-efficiency-d_699.html [Accessed Day Month Year].
