Argon - Thermophysical Properties
Chemical, Physical and Thermal Properties of Argon.
Argon phase diagram
Chemical, physical and thermal properties of Argon  - Ar :
Molecular Weight 39.948
Specific Gravity 1.38
Specific Volume ( ft3 /lb, m3 /kg ) 9.8, 0.622
Density of liquid at atmospheric pressure ( lb/ft3, kg/m3 ) 87.0, 1400
Absolute Viscosity ( lbm /ft s, centipoises ) 13.4 10-6, 0.02
Sound velocity in gas ( m/s ) 322
Specific Heat - cp - ( Btu/lb oF or cal/g oC, J/kgK ) 0.125, 523
Specific Heat Ratio - cp /cv 1.67
Gas constant - R - ( ft lb/lb o R, J/kg oC ) 38.7, 208
Thermal Conductivity ( Btu/hr ft oF, W/m oC ) 0.0102, 0.0172
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - ( oF, oC ) -303, -186
Latent Heat of Evaporation at boiling point ( Btu/lb, J/kg ) 70, 163000
Freezing or Melting Point  at 1 atm ( oF, oC ) -308.5, -189.2
Critical Temperature ( oF, oC ) -187.6, -122
Critical Pressure ( psia, MN/m2 ) 707, 4.87
Critical Volume ( ft3 /lb, m3 /kg ) 0.0299, 0.00186
Flammable no
Follow the link below to get values for the listed properties of argon at varying pressure and temperature :
as well as Thermophysical properties of: Acetone , Acetylene , Air , Ammonia , Benzene , Butane , Carbon dioxide , Carbon monoxide , Ethane , Ethanol , Ethylene , Helium , Hydrogen , Hydrogen sulfide , Methane , Methanol , Nitrogen , Oxygen , Pentane , Propane , Toluene , Water and Heavy water, D2O .
Argon is a gas at standard conditions. However, at low temperature and/or high pressures the gas becomes a liquid or a solid.
The argon phase diagram shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the argon boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
Argon phase diagram
  • The Engineering ToolBox (2008). Argon - Thermophysical Properties. [online] Available at: https://www.engineeringtoolbox.com/argon-d_1414.html [Accessed Day Month Year].
