Anhydrous ammonia , NH3 : Thermophysical properties
- a colorless non-flammable liquefied gas
- vapor is lighter than air - 0.6 compared to air 1.0
- ignition temperature 1204 oF (651 oC) (vapor concentration between 15% and 28% )
- corrodes galvanized metals, cast iron, copper, brass or copper alloys
- weight of liquid ammonia 5.15 pounds per gallon (water weight 8.33 pounds per gallon )
- boiling point liquid ammonia at atmospheric pressure -28 oF (-33.3 oC)
- liquid ammonia expands to 850 times its liquid volume at atmospheric pressure
The vapour pressure of ammonia is the pressure at which ammonia gas is in thermodynamic equilibrium with its condensed state . At higher pressures ammonia would condense . At this equilibrium condition the vapor pressure is the saturation pressure .
See also properties of Ammonia at varying temperature and pressure: Density and specific weight , Dynamic and kinematic viscosity , Prandtl Number , Specific Heat (Heat Capacity) and Thermal Conductivity , and Thermophysical properties at standard conditions.
Ammonia Temperature Pressure Diagram
Saturation (boiling pressures) of liquid ammonia at different temperatures are indicated in the figures below. An ammonia phase diagram is also included:
Temperature | Pressure | Vacuum 1) |
[K] | [°C] | [°F] | [MPa] | [bara] | [psia] | [mm Hg], [torr] | [in Hg] |
222 | -51.1 | -60 | 0.0386 | 0.39 | 5.6 | 460 | 18.1 |
223 | -50.0 | -58 | 0.0407 | 0.41 | 5.9 | 445 | 17.5 |
224 | -49.4 | -57 | 0.0421 | 0.42 | 6.1 | 435 | 17.1 |
224 | -48.9 | -56 | 0.0434 | 0.43 | 6.3 | 424 | 16.7 |
225 | -48.3 | -55 | 0.0448 | 0.45 | 6.5 | 414 | 16.3 |
225 | -47.8 | -54 | 0.0469 | 0.47 | 6.8 | 398 | 15.7 |
226 | -47.2 | -53 | 0.0483 | 0.48 | 7.0 | 388 | 15.3 |
226 | -46.7 | -52 | 0.0496 | 0.50 | 7.2 | 378 | 14.9 |
227 | -46.1 | -51 | 0.0510 | 0.51 | 7.4 | 367 | 14.5 |
228 | -45.6 | -50 | 0.0531 | 0.53 | 7.7 | 352 | 13.9 |
228 | -45.0 | -49 | 0.0545 | 0.54 | 7.9 | 342 | 13.4 |
229 | -44.4 | -48 | 0.0565 | 0.57 | 8.2 | 326 | 12.8 |
229 | -43.9 | -47 | 0.0579 | 0.58 | 8.4 | 316 | 12.4 |
230 | -43.3 | -46 | 0.0600 | 0.60 | 8.7 | 300 | 11.8 |
230 | -42.8 | -45 | 0.0621 | 0.62 | 9.0 | 285 | 11.2 |
231 | -42.2 | -44 | 0.0634 | 0.63 | 9.2 | 274 | 10.8 |
231 | -41.7 | -43 | 0.0655 | 0.66 | 9.5 | 259 | 10.2 |
232 | -41.1 | -42 | 0.0676 | 0.68 | 9.8 | 243 | 9.6 |
233 | -40.6 | -41 | 0.0696 | 0.70 | 10.1 | 228 | 9.0 |
233 | -40.0 | -40 | 0.0717 | 0.72 | 10.4 | 212 | 8.4 |
234 | -39.4 | -39 | 0.0738 | 0.74 | 10.7 | 197 | 7.7 |
234 | -38.9 | -38 | 0.0758 | 0.76 | 11.0 | 181 | 7.1 |
235 | -38.3 | -37 | 0.0786 | 0.79 | 11.4 | 161 | 6.3 |
235 | -37.8 | -36 | 0.0807 | 0.81 | 11.7 | 145 | 5.7 |
236 | -37.2 | -35 | 0.0834 | 0.83 | 12.1 | 124 | 4.9 |
236 | -36.7 | -34 | 0.0855 | 0.85 | 12.4 | 109 | 4.3 |
237 | -36.1 | -33 | 0.0883 | 0.88 | 12.8 | 88 | 3.5 |
238 | -35.6 | -32 | 0.0903 | 0.90 | 13.1 | 73 | 2.9 |
238 | -35.0 | -31 | 0.0931 | 0.93 | 13.5 | 52 | 2.0 |
239 | -34.4 | -30 | 0.0958 | 0.96 | 13.9 | 31 | 1.2 |
239 | -33.9 | -29 | 0.0986 | 0.99 | 14.3 | 11 | 0.4 |
Gauge pressure 2) | |||||||
[psig] | |||||||
240 | -33.3 | -28 | 0.1014 | 1.01 | 14.7 | 0 | |
240 | -32.8 | -27 | 0.1041 | 1.04 | 15.1 | 0.4 | |
241 | -32.2 | -26 | 0.1076 | 1.08 | 15.6 | 0.9 | |
241 | -31.7 | -25 | 0.1103 | 1.10 | 16.0 | 1.3 | |
242 | -31.1 | -24 | 0.1131 | 1.13 | 16.4 | 1.7 | |
243 | -30.6 | -23 | 0.1165 | 1.17 | 16.9 | 2.2 | |
243 | -30.0 | -22 | 0.1193 | 1.19 | 17.3 | 2.6 | |
244 | -29.4 | -21 | 0.1227 | 1.23 | 17.8 | 3.1 | |
244 | -28.9 | -20 | 0.1262 | 1.26 | 18.3 | 3.6 | |
245 | -28.3 | -19 | 0.1296 | 1.30 | 18.8 | 4.1 | |
245 | -27.8 | -18 | 0.1331 | 1.33 | 19.3 | 4.6 | |
246 | -27.2 | -17 | 0.1365 | 1.37 | 19.8 | 5.1 | |
246 | -26.7 | -16 | 0.1400 | 1.40 | 20.3 | 5.6 | |
247 | -26.1 | -15 | 0.1441 | 1.44 | 20.9 | 6.2 | |
248 | -25.6 | -14 | 0.1475 | 1.48 | 21.4 | 6.7 | |
248 | -25.0 | -13 | 0.1517 | 1.52 | 22.0 | 7.3 | |
249 | -24.4 | -12 | 0.1558 | 1.56 | 22.6 | 7.9 | |
249 | -23.9 | -11 | 0.1600 | 1.60 | 23.2 | 8.5 | |
250 | -23.3 | -10 | 0.1634 | 1.63 | 23.7 | 9 | |
250 | -22.8 | -9 | 0.1682 | 1.68 | 24.4 | 9.7 | |
251 | -22.2 | -8 | 0.1724 | 1.72 | 25.0 | 10.3 | |
251 | -21.7 | -7 | 0.1765 | 1.77 | 25.6 | 10.9 | |
252 | -21.1 | -6 | 0.1813 | 1.81 | 26.3 | 11.6 | |
253 | -20.6 | -5 | 0.1855 | 1.85 | 26.9 | 12.2 | |
253 | -20.0 | -4 | 0.1903 | 1.90 | 27.6 | 12.9 | |
254 | -19.4 | -3 | 0.1951 | 1.95 | 28.3 | 13.6 | |
254 | -18.9 | -2 | 0.1999 | 2.00 | 29.0 | 14.3 | |
255 | -18.3 | -1 | 0.2048 | 2.05 | 29.7 | 15 | |
255 | -17.8 | 0 | 0.2096 | 2.10 | 30.4 | 15.7 | |
256 | -17.2 | 1 | 0.2151 | 2.15 | 31.2 | 16.5 | |
256 | -16.7 | 2 | 0.2199 | 2.20 | 31.9 | 17.2 | |
257 | -16.1 | 3 | 0.2255 | 2.25 | 32.7 | 18 | |
258 | -15.6 | 4 | 0.2310 | 2.31 | 33.5 | 18.8 | |
258 | -15.0 | 5 | 0.2365 | 2.36 | 34.3 | 19.6 | |
259 | -14.4 | 6 | 0.2420 | 2.42 | 35.1 | 20.4 | |
259 | -13.9 | 7 | 0.2475 | 2.48 | 35.9 | 21.2 | |
260 | -13.3 | 8 | 0.2537 | 2.54 | 36.8 | 22.1 | |
260 | -12.8 | 9 | 0.2592 | 2.59 | 37.6 | 22.9 | |
261 | -12.2 | 10 | 0.2654 | 2.65 | 38.5 | 23.8 | |
261 | -11.7 | 11 | 0.2717 | 2.72 | 39.4 | 24.7 | |
262 | -11.1 | 12 | 0.2779 | 2.78 | 40.3 | 25.6 | |
263 | -10.6 | 13 | 0.2841 | 2.84 | 41.2 | 26.5 | |
263 | -10.0 | 14 | 0.2910 | 2.91 | 42.2 | 27.5 | |
264 | -9.4 | 15 | 0.2972 | 2.97 | 43.1 | 28.4 | |
264 | -8.9 | 16 | 0.3041 | 3.04 | 44.1 | 29.4 | |
265 | -8.3 | 17 | 0.3110 | 3.11 | 45.1 | 30.4 | |
265 | -7.8 | 18 | 0.3178 | 3.18 | 46.1 | 31.4 | |
266 | -7.2 | 19 | 0.3254 | 3.25 | 47.2 | 32.5 | |
266 | -6.7 | 20 | 0.3323 | 3.32 | 48.2 | 33.5 | |
267 | -6.1 | 21 | 0.3399 | 3.40 | 49.3 | 34.6 | |
268 | -5.6 | 22 | 0.3475 | 3.47 | 50.4 | 35.7 | |
268 | -5.0 | 23 | 0.3551 | 3.55 | 51.5 | 36.8 | |
269 | -4.4 | 24 | 0.3627 | 3.63 | 52.6 | 37.9 | |
269 | -3.9 | 25 | 0.3702 | 3.70 | 53.7 | 39 | |
270 | -3.3 | 26 | 0.3785 | 3.79 | 54.9 | 40.2 | |
270 | -2.8 | 27 | 0.3868 | 3.87 | 56.1 | 41.4 | |
271 | -2.2 | 28 | 0.3951 | 3.95 | 57.3 | 42.6 | |
271 | -1.7 | 29 | 0.4033 | 4.03 | 58.5 | 43.8 | |
272 | -1.1 | 30 | 0.4116 | 4.12 | 59.7 | 45 | |
278 | 4.4 | 40 | 0.5054 | 5.05 | 73.3 | 58.6 | |
283 | 10.0 | 50 | 0.6150 | 6.15 | 89.2 | 74.5 | |
289 | 15.6 | 60 | 0.7419 | 7.42 | 107.6 | 92.9 | |
294 | 21.1 | 70 | 0.8880 | 8.88 | 128.8 | 114.1 | |
298 | 24.4 | 76 | 0.9860 | 9.86 | 143.0 | 128.3 | |
298 | 25.0 | 77 | 1.00 | 10.0 | 145.4 | 130.7 | |
299 | 25.6 | 78 | 1.02 | 10.2 | 147.9 | 133.2 | |
299 | 26.1 | 79 | 1.04 | 10.4 | 150.5 | 135.8 | |
300 | 26.7 | 80 | 1.05 | 10.5 | 153.0 | 138.3 | |
300 | 27.2 | 81 | 1.07 | 10.7 | 155.6 | 140.9 | |
301 | 27.8 | 82 | 1.09 | 10.9 | 158.3 | 143.6 | |
301 | 28.3 | 83 | 1.11 | 11.1 | 161.0 | 146.3 | |
302 | 28.9 | 84 | 1.13 | 11.3 | 163.7 | 149.0 | |
303 | 29.4 | 85 | 1.15 | 11.5 | 166.4 | 151.7 | |
303 | 30.0 | 86 | 1.17 | 11.7 | 169.2 | 154.5 | |
304 | 30.6 | 87 | 1.19 | 11.9 | 172.0 | 157.3 | |
304 | 31.1 | 88 | 1.21 | 12.1 | 174.8 | 160.1 | |
305 | 31.7 | 89 | 1.23 | 12.3 | 177.7 | 163.0 | |
305 | 32.2 | 90 | 1.25 | 12.5 | 180.6 | 165.9 | |
306 | 32.8 | 91 | 1.27 | 12.7 | 183.6 | 168.9 | |
306 | 33.3 | 92 | 1.29 | 12.9 | 186.6 | 171.9 | |
307 | 33.9 | 93 | 1.31 | 13.1 | 189.6 | 174.9 | |
308 | 34.4 | 94 | 1.33 | 13.3 | 192.7 | 178.0 | |
308 | 35.0 | 95 | 1.35 | 13.5 | 195.8 | 181.1 | |
309 | 35.6 | 96 | 1.37 | 13.7 | 198.9 | 184.2 | |
309 | 36.1 | 97 | 1.39 | 13.9 | 202.1 | 187.4 | |
310 | 36.7 | 98 | 1.42 | 14.2 | 205.3 | 190.6 | |
310 | 37.2 | 99 | 1.44 | 14.4 | 208.6 | 193.9 | |
311 | 37.8 | 100 | 1.46 | 14.6 | 211.9 | 197.2 | |
311 | 38.3 | 101 | 1.48 | 14.8 | 215.2 | 200.5 | |
312 | 38.9 | 102 | 1.51 | 15.1 | 218.6 | 203.9 | |
313 | 39.4 | 103 | 1.53 | 15.3 | 222.0 | 207.3 | |
313 | 40.0 | 104 | 1.55 | 15.5 | 225.4 | 210.7 | |
314 | 40.6 | 105 | 1.58 | 15.8 | 228.9 | 214.2 | |
314 | 41.1 | 106 | 1.60 | 16.0 | 232.5 | 217.8 | |
315 | 41.7 | 107 | 1.63 | 16.3 | 236.0 | 221.3 | |
315 | 42.2 | 108 | 1.65 | 16.5 | 239.7 | 225.0 | |
316 | 42.8 | 109 | 1.68 | 16.8 | 243.3 | 228.6 | |
316 | 43.3 | 110 | 1.70 | 17.0 | 247.0 | 232.3 | |
317 | 43.9 | 111 | 1.73 | 17.3 | 250.8 | 236.1 | |
318 | 44.4 | 112 | 1.75 | 17.5 | 254.5 | 239.8 | |
318 | 45.0 | 113 | 1.78 | 17.8 | 258.4 | 243.7 | |
319 | 45.6 | 114 | 1.81 | 18.1 | 262.2 | 247.5 | |
319 | 46.1 | 115 | 1.84 | 18.4 | 266.2 | 251.5 | |
320 | 46.7 | 116 | 1.86 | 18.6 | 270.1 | 255.4 | |
320 | 47.2 | 117 | 1.89 | 18.9 | 274.1 | 259.4 | |
321 | 47.8 | 118 | 1.92 | 19.2 | 278.2 | 263.5 | |
321 | 48.3 | 119 | 1.95 | 19.5 | 282.3 | 267.6 | |
322 | 48.9 | 120 | 1.97 | 19.7 | 286.4 | 271.7 | |
330 | 56.9 | 134 | 2.42 | 24.2 | 351.1 | 336.4 | |
350 | 76.9 | 170 | 3.87 | 38.7 | 560.7 | 546.0 | |
370 | 96.9 | 206 | 5.88 | 58.8 | 852.5 | 837.8 | |
390 | 117 | 242 | 8.60 | 86.0 | 1248 | 1233 | |
400 | 127 | 260 | 10.3 | 103 | 1495 | 1480 | |
405 | 132 | 270 | 11.3 | 113 | 1645 | 1630 |
1) Between -60 oF (-51 oC) to -28 oF (-33 oC) the vacuum pressure values in the seventh and eighth column are represented in mm and inches Mercury
2) The gauge numbers shown in that seventh column all are vs atmospheric pressure at sea level (14.7 psia)
Air Conditioning Systems
Design of Air Conditioning systems - heating, cooling and dehumidification of indoor air for thermal comfort. -
Boiling Points of Fluids
Boiling points of elements, products and chemical species at varying conditions. -
Material Properties
Thermodynamics
Online calculator, figures and tables showing dynamic (absolute) and kinematic viscosity of gasous and liquid ammonia at temperatures ranging from -73 to 425°C (-100 to 800°F) at pressure ranging from 1 to 1000 bara (14.5 - 14500 psia) - SI and Imperial Units. -
Ammonia and health symptoms - smell and threat to life. -
Thermodynamic properties of saturated and superheated ammonia R-717 like specific volume, enthalpy and entropy. -
Figures and table with changes in Prandtl number for ammonia with changes in temperature and pressure. -
Figures and tables showing how the properties of liquid and gaseous ammonia changes along the boiling/condensation curve (temperature and pressure between triple point and critical point conditions). An ammonia phase diagram are included. -
Online calculator, figures and tables showing specific heat, CP and CV, of gasous and liquid ammonia at temperatures ranging from -73 to 425°C (-100 to 800°F) at pressure ranging from 1 to 100 bara (14.5 - 1450 psia) - SI and Imperial Units. -
Online calculator, figures and tables showing thermal conductivity of liquid and gaseous ammonia at temperatures ranging -70 to 425 °C (-100 to 800 °F) at atmospheric and higher pressure - Imperial and SI Units. -
Chemical, Physical and Thermal Properties of Ammonia. Phase diagram included. -
Online calculator with figures and tables showing density and specific weight of ammonia for temperatures ranging -50 to 425 °C (-50 to 800 °F) at atmospheric and higher pressure - Imperial and SI Units. -
Critical temperatures and pressures for some common substances like air, alcohol, ether, oxygen and more. -
Density Converter
Online density converter with commonly used units. -
Boiling temperatures (°C and °F) with varying carbon numbers up to C33. -
Density, specific heat, thermal conductivity, viscosity and Prandtls no. of liquid ammonia at saturation pressure. -
Liquids and Fluids - Specific Heats
Specific heats for some common liquids and fluids - acetone, oil, paraffin, water and many more. -
Boiling temperatures for common liquids and gases - acetone, butane, propane and more. -
Convert between pressure units like Pa, bar, atmosphere, pound square feet, psi and more. -
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
