Stress
Stress is the ratio between applied force and cross-sectional area where the applied force is acting.
Normal Stress
Normal stress can be expressed as
σ = FN / A                           (1)
σ = normal stress (N/m2, Pa, psi)
FN = applied force perpendicular to the area - Normal force (N, lb)
A = cross-sectional area (m2, in2)
Shear Stress
Shear stress can be expressed as
τ = FV / A                           (2)
τ = shear stress (N/m2, Pa, psi)
FV = applied force in plane of the area - Shear force (N, lb)
Example - Normal Stress in a Column
he-a steel beam
A 10000 N force is acting in the direction of a British Universal Column UB 152 x 89 x 16 with cross sectional area 20.3 cm2. The normal stress in the column can be calculated as
σ = (10000 N) / ((20.3 cm2) (0.0001 m2/cm2
   = 4926108 Pa (N/m2)
   = 4.9 MPa
The Yield strength - the amount of stress that a material can undergo before moving from elastic deformation into plastic deformation - is typical 250 MPa for steel.
Example - Shear Stress in a Beam with Point Load
Beam with point load - shear force
For a beam with single point load supported on both ends - the shear force Fv (or V in the figure above) is equal in magnitude to support force R1 or R2.
Reaction forces can be calculated due to moment equilibrium around support 1
F L / 2 = R2 L                              (4)
R2 = F / 2                              (5)
R1 = R2 = F / 2                         (6)
For a 10000 N point load perpendicular on a beam similar to the example above - supported at both ends - the magnitude of the reaction and shear forces can be calculated as
R1 = R2
    = V1
    = V2
    = (10000 N) / 2
    = 5000 N
    = 5 kN
The shear stress can be calculated as
τ = (5000 N) / ((20.3 cm2) (0.0001 m2/cm2)
  = 2463054 Pa
           = 2.5 MPa
  • Mechanics
  • Statics
  • The Engineering ToolBox (2008). Stress. [online] Available at: https://www.engineeringtoolbox.com/stress-d_1395.html [Accessed Day Month Year].
