Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Physical properties of some common refrigerants:
For full table with Freezing Points and Critical Points - rotate the screen!
Refrigerant No. | Name | Molecular Mass | Boiling point at atmospheric pressure 14.7 psia, 1 bar abs (oF) | Freezing Point at atmospheric pressure 14.7 psia, 1 bar abs (oF) | Critical Point | ||
Temperature (oF) | Pressure (psia) | Specific Volume (Cu.Ft./lb.) | |||||
R-10 | Carbontetrachloride | 153.8 | 170.2 | ||||
R-11 | Trichlorofluoromethane1) | 137.37 | 74.9 | -168 | 388 | 640 | 0.0289 |
R-12 | Dichlorodifluoromethane2) | 120.91 | -21.8 | -252 | 234 | 597 | 0.0287 |
R-13 | Monochlorotrifluoromethane | 104.46 | -114.6 | -294 | 84 | 561 | 0.0277 |
R-13B1 | Bromotrifluoromethane | 148.91 | -72 | -270 | 153 | 575 | 0.0215 |
R-14 | Tetrafluoromethane (Carbon tetrafluoride) | 88.00 | -198.2 | -299 | -50 | 543 | 0.0256 |
R-14 | Chloroform | 119.4 | 142 | ||||
R-21 | Dichloro-fluoromethane | 102.92 | 48.1 | -211 | |||
R-22 | Difluoromonochloromethane3) | 86.468 | -41.3 | -256 | 205 | 722 | 0.0305 |
R-23 | Trifluormethane | 70 | -119.9 | ||||
R-30 | Methylene Chloride | 84.9 | 105.2 | ||||
R-31 | Monochloromonofluoromethane | 68.5 | 48.0 | ||||
R-32 | Methylene Fluoride | 52.0 | -61.4 | ||||
R-40 | Chloromethane (Methyl Chloride) | 50.488 | -10.7 | -144 | 290 | 969 | 0.0454 |
R-41 | Methyl Fluoride | 34.0 | -109 | ||||
R-50 | Methane | 16.044 | -259 | -296.6 | |||
R-110 | Hexachloroethane | 236.8 | 365 | ||||
R-111 | Pentachloromonofluoroethane | 220.3 | 279 | ||||
R-112 | Tetrachlorodifluoroethane | 203.8 | 199.0 | ||||
R-113 | Trichlorotrifluoroethane4) | 187.39 | 118 | -31 | 417 | 499 | 0.0278 |
R-114 | 1,2-dichloro-1,1,2,2-tetrafluoroethane | 170.92 | 38.4 | -137 | 294 | 473 | 0.0275 |
R-115 | Chloropentafluoroethane | 154.47 | -38.0 | -149 | 176 | 458 | 0.0261 |
R-116 | Hexafluoroethane | 138.0 | -108.8 | ||||
R-120 | Pentachloroethane | 202.3 | 324 | ||||
R-123 | Dichlorotrifluoroethane5) | 152.93 | 82 | -161 | 363 | 533 | |
R-124 | Monochlorotetrafluoroethane | 136.5 | 10.4 | ||||
R-125 | Pentafluoroethane | 120 | -55 | ||||
R-133a | Monochlorotrifluoroethane | 118.5 | 43.0 | ||||
R-134a | Tetrafluoroethane6) | 102.03 | -15 | -142 | 214 | 590 | 0.0290 |
R-140a | Trichloroethane | 133.4 | 165 | ||||
R-142b | 1-chloro-1,1-difluoroethane | 100.50 | 14 | -204 | 279 | 598 | 0.0368 |
R-143a | Trifluoroethane | 84 | -53.5 | ||||
R-150a | Dichloroethane | 98.9 | 140 | ||||
R-152a | Difluoroethane | 66.05 | -13 | ||||
R-160 | Ethyl Chloride | 64.515 | 12.2 | -218 | |||
R-170 | Ethane | 30.070 | -127 | -278 | 90 | 710 | 0.0830 |
R-218 | Octafluoropropane | 188 | -36.4 | ||||
R-290 | Propane | 44.097 | -44 | -309.8 | 206 | 617 | 0.0728 |
RC-318 | Octafluorocyclobutane | 200.04 | 22 | -43 | 240 | 404 | 0.0258 |
R-410A | R-32 Difluoromethane (50% weight), R-125 Pentafluoroethane (50% weight) | 72.6 | -55.4 | 162 | 690 | ||
R-500 | Dichlorodifluoromethane/ Difluoroethane7) |
99.31 | -28 | -254 | 222 | 642 | 0.0323 |
R-502 | Chlorodifluoromethane/ Chloropentafluoroethane |
111.63 | -50 | 180 | 591 | 0.0286 | |
R-503 | Chlorotrifluoromethane/ Trifluoromethane |
87.50 | -128 | 67 | 607 | 0.0326 | |
R-600 | n-Butane | 58.12 | 31.2 | -217 | 306 | 551 | 0.0702 |
R-600a | Isobutane (2-Methyl propane) | 58.12 | 10.8 | -229 | 275 | 529 | 0.0725 |
R-611 | Methyl formate | 60.05 | 89 | -146 | 417 | 870 | 0.0459 |
R-702 | Hydrogen | 2.016 | -423 | -434.6 | |||
R-704 | Helium | 4.0026 | -452 | ||||
R-717 | Ammonia | 17.02 | -28 | -107.9 | 271 | 1657 | 0.0680 |
R-720 | Neon | 20.179 | -410.9 | -415.6 | |||
R-728 | Nitrogen | 28.0134 | -320.4 | -346 | |||
R-729 | Air | 28.966 | -320 | -357.2 | |||
R-732 | Oxygen | 31.9988 | -297.3 | -361.3 | |||
R-740 | Argon | 39.948 | -303 | -308.5 | |||
R-744 | Carbon Dioxide | 44.01 | -109.4 | -70 | 88 | 1070 | 0.0342 |
R-744A | Nitrous Oxide | 44.012 | -127.3 | -131.5 | |||
R-764 | Sulfur Dioxide | 64.06 | 14.0 | -104 | 316 | 1143 | 0.0306 |
R-1150 | Ethylene | 28.05 | -155 | -272 | 49 | 742 | 0.0700 |
R-1270 | Propylene | 42.08 | -54 | -301 | 197 | 670 | 0.0720 |
1) Production of R11 or CFC-11 was halted by the clean air act on January 1, 1996
2) Production of R12 or CFC-12 (Dichlorodifluoromethane) was halted by the clean air act on January 1, 1996
3) R22 or HCFC-22 is a single component HCFC refrigerant with low ozone depletion potential. It has long been used in a variety of air-conditioning and refrigeration applications in a variety of markets, including appliance, construction, food processing, and supermarkets. Production of R-22 halted in US 2015.
4) Production of R113 or CFC-113 was halted by the clean air act on January 1, 1996
5) R123 or HCFC-123 is a replacement for R11 in chillers and is providing this new refrigerant to chiller manufacturers for use in new and existing chillers
6) Refrigerant R134a or HFC-134a is a commercially available hydrofluorocarbon (HFC) refrigerant for use as a long-term replacement for R-12 in new equipment and for retrofitting medium temperature CFC-12 systems
7) Production of R-500 was halted by the clean air act on January 1, 1996.
Low Pressure, Medium Pressure and High Pressure Refrigerants
Typical low, medium and high pressure refrigerants are listed in the table below:
Refrigerants | ||
Low Pressure | R11 | Trichlorofluoromethane |
R13 | Chlorotrifluoromethane | |
R113 | Trichlorotrifluoroethane | |
R123 | Dichlorotrifluoroethane | |
Medium Pressure | R114 | 1,2-dichloro-1,1,2,2-tetrafluoroethane |
High Pressure | R12 | Dichlorodifluoromethane |
R22 | Chlorodifluoromethane | |
R134a | Tetrafluoroethane | |
R410A | Difluoromethane/Pentafluoroethane | |
R500 | Dichlorodifluoromethane/ Difluoroethane |
R502 | Chlorodifluoromethane/ Chloropentafluoroethane |
CFC, HCFC, HFC and HC Refrigerants
Refrigerants can be classified as CFC's - ChloroFluoroCarbons refrigerants, HCFC's - HydroChloroFluorCarbons refrigerants, HFC's - HydroFluorCarbons refrigerants and HC - HydroCarbon refrigerants.
Refrigerants | ||
CFC ChloroFluoroCarbons |
R12 | Dichlorodifluoromethane | |
R114 | 1,2-dichloro-1,1,2,2-tetrafluoroethane | |
R503 | Chlorotrifluoromethane/ Trifluoromethane |
HCFC HydroChloroFluorCarbons |
R124 | Chlorotetrafluoroethane | |
R401a | R22(53%)/R152a(13%)/R124(34%) | |
R401b | R22(61%)/R152a(11%)/R124(28%) | |
R402a | R22(38%)/R125(60%)/R290(2%) | |
R403b | R22(56%)/R218(39%)/R290(5%) | |
R406a | R22(55%)/R600a(4%)/R142b(41%) | |
R408a | R125(7%)/R143a(46%)/R22(47%) | |
R409a | R22(60%)/R124(25%)/R142b(15%) | |
HFC HydroFluorCarbons |
R23 | Trifluoromethane |
R404a | R125(44%)/R143a(52%)/R134a(4%) | |
R407a | R32(20%)/R125(40%)/R134a(40%) | |
R410a | R32(50%)/R125(50%) | |
R416a | R134a(59%)/R124(39.5%)/R600(1.5%) | |
R507 | R125(50%)/R143a(50%) | |
R508a | R23(39%)/R116(61%) | |
HC HydroCarbons |
R600 | butane |
R600a | iso-butane |
Boiling Points of Fluids
Boiling points of elements, products and chemical species at varying conditions. -
Material Properties
Dichlorodifluoromethane - Properties
Properties of saturated liquid Dichlorodifluoromethane R-12 - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number. -
Dichlorodifluoromethane - Properties, Imperial Units
Properties of saturated liquid Dichlorodifluoromethane - CCl2F2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number. -
Global Temperature Trend
Global temperature trend year 1880 - 2015. -
Boiling temperatures (°C and °F) with varying carbon numbers up to C33. -
Boiling temperatures for common liquids and gases - acetone, butane, propane and more. -
Melting temperature (°C and °F) with carbon number up to C33. -
Net Refrigeration Effect
The quantity of heat absorbed from a refrigerated space. -
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy. -
R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units. -
Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity. -
Refrigerant R134a - Properties
Thermodynamic properties of refrigerant R-134a. -
Refrigerants - Color Codes
Common refrigerants and their color codes. -
Refrigerants - Environmental Properties
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP). -
Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A. -
Refrigerants - Saturation Pressures vs. Temperatures
Temperature and pressure diagram for constant boiling refrigerants - imperial and SI units. -
Triple Points Substances
Triple points for common substances.
